3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The ideas printer
The ideas printer
The purpose of this instructable is to build an "ideas printer". I transformed an old broken HP deskjet 400 in both a container and a workplace to solder, glue, cut and build my projects.
I want also to hide tools when not used.
Step 1Materials
Materials
- old printer
- hot glue
- screwdriver
- soap
- multimeter
- solder
- tools you want to store in the printer
- breadboard
- copper wires
12 comments
Mar 20, 2010. 7:10 PMzack247 says:
now all i need is a printer... (glances at his brand new lexmark x2650)
Feb 14, 2011. 4:50 AMagis68 says:
i have 6 old jetprinters....i can send u one...:)
Nov 7, 2010. 10:06 AMzack247 says:
hey i found the printer in the storage room! hp deskjet 350 (i think) blue, small, and it has a removable paper tray. i think i might add a 5v and 12v power supply using a 22v adapter.
Mar 21, 2010. 10:08 AMzack247 says:
i think i have one in the storage room somewhere. one thing you could do is use a cold cathode light from a scanner as a worklight, and mount it just behind the front of the printer's casing
Mar 22, 2010. 10:08 AMscratchr says:
I have one that needs 15v@1.5a, they don't document the requirements, so i recommend using a adjustable regulator circuit to test the inverter.
Mar 22, 2010. 11:24 AMzack247 says:
yeah. i tried testing my inverter by hooking it up to a regular psu, little did i know it was malfunctioning and the inverter started smoking. then, as i was putting it away, one of the wires broke off of the cathode tube
May 14, 2010. 12:08 AMrenewilson says:
I think that the same can be done with the printer's toner cartridges. It would act like a small portable tool storage place. But am i no t sure that will be good or niot as i have never worked on it
Mar 21, 2010. 8:01 PMscratchr says:
great idea!
Mar 12, 2010. 9:52 AMMisac-kun says:
pretty usefull, i will do one for me when i find an old printer in the junkyard
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
57
Author:derte84(Genteautoreggente!)
