Step 4: The slides outer shape
With the paper in place, i started cutting the pieces, first roughly on the bandsaw, then a little closer on the bandsaw again, but with more easy to handle pieces, and finally on the rotary flap sander. On the flap sander i sanded them down, until i just hit the paper. (remember, you still only have paper one one side of the wood). As you can see in the picture, i have a piece of plastic under my slide when I'm sanding it. This is to avoid scratches and smudge from the metal base it is lying on.
When that was done, i had 8 almost identical pieces, except for the paper of course.
To make sure the diagonal surface was very flat, and would fit its counterpart i set up a little jig, to sand them down to a nice flat line. It was really just a piece of sandpaper on a flat table, and a box with a 90 degree angle on top of the sandpaper. Then i just held the slide to the side of the box, and sanded the diagonal surface.
Now i was able to glue on the rest of the drawings, because the slide had the final outer shape. I cannot stress enough that you need to keep track of the number if the slide! That was why i numbered them all in the first place. The last image is a little ahead, because as you can see, i already started working on the internal detailing.
Remove these ads by
Signing Up
Not Nice
Visit Our Store »
Go Pro Today »
