3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The incredible Steampunk Radio
Based on a USW - Receiver Kit and the idea to have a Radio with a really good sound I decided to make a radio wit a special speaker system.
The Radio is incredible because of its sound. The sound fills the whole room.
Let´s see how to make it.
The green "tube" looks like the old "magic eyes".
Step 1The Parts
The Parts
You need:
  • A DIY radio kit
  • A speaker
  • Some pieces of MDF
  • Water based stain
  • Wax stain
  • Brass screew
  • Brass washers
  • A PVC tube
  • Very thin ply wood
  • A precise potentiometer (10 turns)
  • two knobs
  • A switch
  • A aluminium cone
  • A refurbished lamp
25 comments
Jan 12, 2012. 2:50 PMtwistedsense says:
This looks awesome.
Would it be possible to mount the antenna on the inside of the tube though to hide it from view? Or would that hamper reception?
Jan 14, 2012. 6:43 AMBosun Rick says:
I'm wondering if one could use either brass or aluminum sheeting to cover the tube and act as an antenna?
This would provide a very different look, and if brass were to be used, it would dramatically enhance the "Steampunk" effect! Great project!
Jan 13, 2012. 8:16 PMRob87 says:
Amazing idea.
Just wondering where you got the aluminum cone from?
And what did you use to hold the plywood to the PVC tube when gluing it?
Thanks.
Jan 13, 2012. 1:24 AMCuriousWeasel says:
This looks fantastic !
Could the 'refurbished lamp' be replaced with a Nixie tube like the 6E1P to indicate reception quality ?
Jan 12, 2012. 11:42 PMwrsexton says:
Try here for a radio kit: http://www.scientificsonline.com/am-fm-radio-kit.html
that's Edmund Scientific, scientificsonline dot com. Search radio kit.
Jan 12, 2012. 6:47 AMBonzoix says:
You should add one of these to it... ebay item number 280766324430.
Where in the USA can we acquire one of these radio kits?
Jan 12, 2012. 8:22 AMconmac863 says:
Very nice. Looks really good.
Do you have any dimensions? It looks like it is a pretty good size but I am guessing fairly small just judging by the radio kit but hard to tell really.
Thanks !!!! And great instructable.
Jan 12, 2012. 9:55 AMconmac863 says:
Guten Tag Herr Steam.
Thank you for the dimension. That helps a lot.
Did you play with tube heights or just used a height that was aesthetically pleasing? 80 CM is taller than I thought, but really give it that steampunk look.
Anything special inside with the electronics? The kit has 2 knobs and you added the potentiometer and on/off switch. But I only see 2 knobs and the on/off.
A picture of the inside would be an awesome addition to a great instructable.
Really nice project. Thank you for sharing.
Sean
Jan 12, 2012. 3:03 PMconmac863 says:
Thank you so much for the additional pictures.
I understand much better now :-)
Sean
Jan 12, 2012. 11:51 AMTwoWindsBear says:
Just make a cone from brass shim stock.
GREAT radio!
Jan 12, 2012. 7:53 AMdawp says:
Love the look. I wonder if i could build one into the woodstove pipe to keep my Atwater Kent Radios, Edison Phonograph, Webcor Record Changer, and Carbon Filament lightbulbs entertained:)
Jan 10, 2012. 1:33 AMT-Hawke says:
Awesome Again Sir!!! Your designs are GREAT, and this is no exception!!
My Regards Sir.
Jan 9, 2012. 8:03 AMlongwinters says:
Great look, I'm curious why didn't you use brass bolts and an acorn nuts to hold the top togeather?
Jan 9, 2012. 7:31 AMXenophon says:
Well done, sir!
Jan 9, 2012. 6:34 AMelectfire says:
I really need to finish my desktop Steampunk amplifier.....
Anyways, you have done an amazing job as usual!
Keep up the awesome work and happy making!
(I finally got an Arduino! ~ Sorry couldn't help but to tell everyone.....)
Jan 9, 2012. 6:00 AMstringstretcher says:
Nice piece of SP furniture! Great work.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
89
Author:Horatius.Steam(Steampunk Design)
I am a home constructor, an inventor and a dreamer. If you ask me who guided me and who inspired me then this people comes in mind: Carl Benz, Guglielmo Marconi, James Watt, Thomas Alva Edison, Nicola...
more »
