please excuse my horrible grammer, spelling, and understanding of the english launguage.
Remove these ads by
Signing UpStep 1Tools needed!
The most helpful and productive tool in the inventors arsinal is a a hot glue gun,
ranging from $10-$200 dollars,
I personaly use a $20 glue gun, just about every day, its a wonderful
tool used to heat a synthetic plastic, then squirt said plastic onto a surface, creating a strong, cheap and instant bond (instant being 1-5 minutes)
an Exacto knife and a box cutter
Ranging from $5-$20
again very cheap affordable tools, get 1 of each tool and some extra blades (about 5 for each device) they can cut into most objects, ranging from paper,cardboard,plastic,rubber and alot of other materials.
A drill
Ranging from $40-$500
When it comes to power tools, i use Ryobi its a really cheap place to get good tools, while alot of people say there tools aren't good, i find they work well and get the job done. The only reason i use a drill is because i need to put holes into things (like an axel bearing or rivet, maybe to create a good holding/safety release)
Rarley do i use a drill for screwing things together... lol
Muratiac Acid
$6-$10 per Gallon
Muriatiac acid is great for metal Burning (EI sketching of line cutting) reducation of metal, mold making (i might make an instructable for that, its makign a tin-foil mold, and burning teh tin foil off), Dissolving chemicals, ionising water. Its can be used in alot of things
2 part Expoxy
$2-$20
If the hot glue isn't strong enough, expoxy sure is, its been claimed to be strogner than cement the only downside is that "5 minute dry time" is more like 30.
Dremel
$20-$300
Dremels are cheap or expensive your call, although i prefer the cheaper end. These are like sand-paper on steriods, its used to reach, well, hard to reach spots and sand down anything in no time.
Really I couldn't think of anything else i use..... an inventor tries to make use of what he/she can, in doing so almost and material or tool can be improvised for another. Its all about open thinking, as an expamle I need a cnc milling machine ones ($2k price tag for a 1 time use) I grabbed my mitar saw and slit by slit made an indentation until i had the shape i need. Oddly enough I rarely stray from the tools I listed above... the real deal happens in parts, when sourcing parts one must use the parts more than the tools (EI the part should be right and the tool shouldn't do much work)
Did the person invent the way to make the golfball go farther?
Or was he just the first maximillion to put it in a golf ball?
Not trying to be a pecimist unto you just curious...
But you werent scrutinizing it as i was...
I was talking of a more broad picture....
But i see where you come form and partialy agree....
Adding dimples might help but get some mass int it..
Give'em a lead core!
Same for the clubs... why not?
Also, how do you do those neat things with just a multi-tool?
Often sold as patio or brickwork cleaner, or for adjusting the pH of pools etc.
Its pretty cheap stuff, close to $6-$10 per gallon, and it helps in a wide range of apps, like removing metal, acid cleaning, just make sure you wear lab safety goggles (Ones with side sheild) and lab ro cleaning gloves (The long sleeve plastic or rubber ones)
"Dont try this at home unless you're on instructables"
Pumping
air
imagine
of
lol....
i actually have an idea to use the earths ionosphere as a giant photo-voltaic
