Step 2Circuit Design
- The voltage drop across these blue and red LEDs are 4.5V and 2.2V respectively.
- The voltage across the resistor with a 9v source and the blue LED in series is 4.5V
- The voltage across each resistor with a 9v source and the red LED in series is 6.8V
- The power dissipated by both resistors is ~90mW
If you are going to try different LED and resistor configurations here are some guidelines.
- Connecting your resistors in parallel rather than in series is a lot easier since you have to do the soldering inside the pumpkin.
- If you use blue LEDs you will not be able to hook them in series with a 9v source since there is typically a 4.5v drop across the high intensity type.
- If you are hooking the LEDs up in parallel like we are here and you use a lower valued resistor (<100ohms) you will probably need one with a higher power rating
Add Comment
