The Necklace Hand Plain Tool
3,052
57
8
Posted
Introduction: The Necklace Hand Plain Tool
In this instructable i am going to make wearable and practical mini hand plain for fine shaving.( and if you are not using it you can wear it as an necklaces ) I designed it in a way that when the blade gets dole you can just swap it out with another one.
Step 1: Prepare the Wood
For this project i used dry cherry wood. but before i could use it i had to take of the bark and make it square .i did this by using a big gardening tool witch i don't now the English name for ( pic.2 )
Step 2: Shaping and Drill the Hole for the Cord
i first rounded over the corners of the block of wood, than i used my drill to make a hole for the cord to go trough
Step 3: Saw the Notch
i used my metal saw for this step because it has a thinner blade than a regular wood saw. if you still use a normal saw you can just put some tape over the blade to make a closer fit .
Step 4: Burn in Your Design (optional)
i used my old soldering iron to burn in the skull. this step is not hard but be careful because you can easily burn your fingers
Step 5: Sanding,oil and the Blade
u sanded up to 200 grid before adding a oil finish. Despite of the thin metal curing blade i used for the notch the blade was still to loose .to fix this i used some painters tape .
and until the next instructable goodbye
sir. Woodster
  • Science of Cooking
    Science of Cooking
  • Microcontroller Contest
  • Spotless Contest
    Spotless Contest
7 Comments
Thank you! I have been looking for a tool like this. I didn't make it into a necklace though. But thanks!
wat kinde of wood did you use ?
I don't know what kind it was. I found a plank of wood in the garage. I sawed and cut it to the correct dimensions.
Great Instructable. Thanks for sharing your build with us! Did you glue in the blade at all?
no , i didn`t have a metal-wood glue and it already stays in place with the in-word`s tension from the wood. so if it dous not stays in place just add some extra tape
