The Paracord Belt
9,097
303
10
Posted
Introduction: The Paracord Belt
Today I will be showing you how to make this awsome belt out of paracord.
*Since this instructable is confusing try to follow the pictures, because what I can't put into words will be explained by the pictures.
Step 1: Materials
For this instuctable you will need each of the following:
x1 a belt buckle
x2 32ft of paracord
x1 4.5ft of paracord
scisors
lighter
imagination
Step 2:
Take the middle of the shorter cord and fold it in half,and make a cow hitch around the middle of the buckle.
Step 3:
take one of the other cords and make one side the same length as the other cord on the buckle and make a cow hitch, and repeat with the third cord so that there are three cow hitches in a row.
Step 4:
take the cords and divide them in half, then take the right outer cord and loop it under the two inner cords. Then take the left outer most cord and loop it over and through the loop of the outer right cord, and tighten the cords.
Step 5:
repeat the last step until the desired length or go onto the next step to make the belt look cooler.
Step 6:
after repeating step 4 about 10 times I decided to change the pattern of the belt.
First what you do is you loop the right outer cord over the cords then take the left outer cord and loop it under and through the right cord. then reapeat step 4 once and reapeat this step again.
Step 7:
once there is about 1-2 inches left start doing cobra braids until there is almost no moe core. cut and singe the core close enougth that the core won't go inside the belt but not so that it is sticking way out, and cut and singe the outerr cords so that the belt won't unravel.
Step 8:
The end.
have fun making this belt, and please vote for me on the survival contest.
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    10 Comments
    Why do you need 4.5ft paracord for? Do you mean that 3 cords is 32ft each?
    The 4.5 ft of paracord is the paracord being wrapped; the center one. The 2 32' strands are the ones being wrapped around the center
    I just wanted to know what is the name of this type of weave called.
    Cool! Do you have any formula for determining length so there is less waste or do you just kind of wing it?
    I kind of winged it, but I only had about 6ft left over, but you can easily do something with the leftover.
    Maybe I will do it on leather..
    Great method! Way less complicated than others i have seen
    Better belt tutorial than others I've seen - thanks!
