3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The remote car that can go enywhere
This is a car that can go anywhere you want to it water,land and many more places!!
to make this car the things that you will need are:-
1.a old car that has it motor of rear wheels and front turning motor
2.you need 2 of 9volt batteries
3.2 or 1 meter wire,that could be any wire bell wire,etc.
4.1 switch or 2 for the front wheels.
5.tou can use sholdering iron but if you dont you can use electric tape
Step 1Step 1
step 1
In this picture you can see the rear part that is the rear motor that runs.
If you see in the old car that you are using for the car you will have a motor,
with that your car runs.
10 comments
Oct 21, 2011. 11:41 AMkenglish says:
acksheep13, Layoff....the kids 11
Nov 21, 2010. 4:48 PMRetroPlayer says:
It works in water because there are no actual electronics, just motors and a battery. And it is not a shock hazard, because the voltages are just way too low. However, not sealing your motors, batteries, and wire will eventually cause the system to fail from corrosion. Especially, the motors. You are drying out all the lubricant from the motors by running them in water.
Putting DC motors under water is an old trick, actually. When you buy a high powered RC motor, for example, it is a good idea to connect it to a battery and run it in a cup of water to clean all the junk out of it. Then you run it in a cup of light oil to relube it. Not relubing it will cause all kinds of trouble in the motor eventually.
The only thing in this project that could be a safety hazard is the battery. Water and the chemicals inside the battery can cause all kinds of reactions. Lithium and water can cause huge explosions.
Oct 4, 2009. 3:42 AMaliyevzaur1989 says:
How can it go in or on the water? P.S. sorry for my bad english
Apr 17, 2010. 8:45 AMTSC says:
It just does i made  one like this and it drives in are bathtup  with water in it with no   problem!!!
Sep 12, 2010. 9:43 AMzack247 says:
i think it might be because its so light. it very well could be buoyant enough to float on water.
Sep 12, 2010. 5:43 PMTSC says:
Hmm!
Apr 30, 2010. 12:41 PMjules15 says:
I bet it can't go to the center of the universe!!
Apr 17, 2010. 10:32 AMTSC says:
Nice sweet!!!!!!!!
Jul 16, 2009. 4:59 PMacksheep13 says:
i don't think you have any education with electronics and safety since both of your current instructables lead to shocking hazards sorry to be rude but please try to think about safety first
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:vinit_johann
I m a 11 years boy and i like to make things and make houses of cards
