Remove these ads by
Signing UpStep 1Forewords
First of all, safety. Notice that this is a mains powered device so maximum care must be taken in the design to insure that for no reason someone may come into contact with live parts. If you are not sure about medium voltage (mains) electrical wiring practice ask a friend or someone else whom is.
green is ground
white or gray is neutral
black is hot leg or #1 in multiphase
red is " " #2 " " "
blue is #3 in 120?208 multiphase
orange is # in multiphase or a high leg in a Delta
brown is # in
hey its been so long that my brain is in the wrong phase. sorry look it up and be careful.
remember that if you are not grounded shock potential is minimized or eliminated BUT trickle currents can still shock the doggy doo out of you.
stand on a dry insulator if you MUST work on a live mains situation
try not to do work without another person close by
try to learn to give CPR as coronary arrest usually occurs in electrocution
And generally if in doubt DON'T $#% with live circuits.
BE CAREFUL and BE RESPECTFUL and be SAFE
You could also use it to erase eproms =)
2 1/2 thumbs up! (where does the half come from? nobody knows!)
That wavelength has the light of the tubes?
Thanks
radiakldesig.comradiakldesig.com
Thanks to Phillip Torrone (of Makezine).
Ciao e apresto 5Volt
By the way, I've had excellent luck exposing PCBs with regular fluorescent lamps-- so I don't think that you *need* to use the UV bulbs. (Although they do look *seriously* cool.) Do they significantly cut down on the exposure time that you need? I remember using about seven minutes per side with regular fluorescent bulbs.
