The Safe and Easy LED BULB
2,356
15
Posted
Introduction: The Safe and Easy LED BULB
There are many LED bulb  instructables  that are based on
1. the  capacitive  droppers  : dangerous as there is no isolation  from  mains the  inrush  current  fries most LEDs
2. difficult to  get components also lengthy work to solder many components
 Here we do it in a easy way
 The  LED bulb is a simple LED sec with 2 or 3 Nos of 0.5watt LEDs  no no more soldering  garden of leds .
 We eliminate the component  buying with a cheapo  5V phone  USB   charger . The arrangement is simple as follows
 Cell USB  charger ---> CCS(Constant current source )---- > LEDs in parallel
 The  CCS takes care of efficient  usage of the  LED at peak brightness.
Step 1: Get the Components
you need
 1 - 1k  resistor
 1- bc548 or any NPN small transistor
 2-1N4148diodes
 1- 10E resistor
 1 or 3 Nos of .5 watt  high bright LEDs
 any 900mA 5v usb phone charger
 here  in INDIA these  are 1$ or less
some verroboard  solder etc
Step 2: Make the Ccs
Make the  CCS on  the board
 I have used this
http://www.scienceprog.com/building-simple-constant-current-power-led-driver/
one with
R2=10ohm  for one  LED , Use 2 ohm for three LEDS
R1=1k  and  rest all same
Supply the  CCS with the  5V from  the  charger.I think there are many diagrams that tell how to get 5v from charger
refer http://www.mytempfiles.info/hdkeychain/USB_Special_Cable_11.gif
for usb socket A pins to get the 5V .
Place the  charger dismantled circuit + the  LED ccs board in  a slim plastic box
Use double sided TAPE to fix to wall
use a 2 terminal blocks to connect mains wires to the obvious MAINS pins of the charger circuit
The CCS circuit has the ability to give max brightness with the  max possible light from the  LEDs .
yey! you have made a handy LED BULB that concumes <2watt and  enough for corner positions of a mini room
No shock ... no hassle .... save lot of $$ on bills .
  • Gluten Free Challenge
  • Paper Contest 2018
    Paper Contest 2018
