But before we get into the actual construction, first we should try to tackle the why.
A good workspace, is an often overlooked issue. If you are starting out with very few resources (time, money, or experience) to build a workspace. The logical choice would be to make the biggest change with the smallest expenditure of resources. A good set of sawhorses is an example of such an expenditure. They are well designed companion for tradespeople around the world. If built correctly you should be able to set them down in a blank empty work area and have a workbench, table, chair, step stool, extra person, scaffold, desk, coat rack, or most importantly a place to set your coffee
There are old timer carpenters who will tell you the story of being asked to build a sawhorse as an interview for the first carpenter job that they got. Today in the days of large box home improvement stores, and injection molded plastic, a set of sawhorses are more likely to be purchased then built.
So why build your own? Many simple reasons.
1) You get a design the fits you when you are working with them. Are you very short or Very tall? What are you going to be putting on them? How tall is it? Are you working in a basement with limited height? Do you work more with dimensional lumber or sheet goods?
2) You get a design that fits you when you are not working with them. Can they be designed to store away in a unused corner? Next to the washing machine? Tuck under your workbench? Slide behind the couch?
3) Cost. A solid set of sawhorses that you build yourself can be made from scrap and cost far less then something you buy pre-built. And that savings translates into more freedom to finance the next project.
4) its a good first project. Practice makes perfect. If you have made it this far you are interested in woodworking. Why not crank out a simple project that is low cost, satisfying to build and will help you with every project down the road?
5) Because its your own. Anyone can go buy something, but if you have a quick look around this website you can tell that we all would rather create something.
6) Because you get to build something the way your grandfather(or mother) would have done it.
7) You just find the smell of sawdust appealing. Don't worry, I understand, relax you are among friends.
Remove these ads by
Signing UpStep 1The Design.
None of that here.
What I wanted was a simple design that can be adapted to whatever materials are available, built by anyone who can cut wood and drive screws. It should be strong, and hard to knock over. You should be able to clamp workpieces to it easily. It needs to stack. It needs to be low cost. It needs a wide enough top that you can just use one if you need to. It should be easy to replicate when you decide you need to build another set, or speaking from experience when it gets left in the driveway, and you back over it. It should be adaptable to different heights.
The pictures show what I came up with. I borrowed many ideas for this project from other peoples designs I have seen over the years. Its a simple 2x8" top roughly 2 feet long. with 2 foot legs. The low height is perfect for working on large box 'cabinet' type projects. It works well for ripping down plywood and working with a circular saw. It works in low ceilinged basements. The 15 degree spread of the legs gives a wide stable stance. (If you want to make a taller set I would decrease the angle a bit.) And the lack of bracing allows the legs to flex and sit on uneven concrete floors with out rocking. And allows them to stack even if they all do not get built exactly the same.
The tools needed are simple, you need some way to cut wood, some way to drive screws, and a carpenters square, that's it. The first set these that I built was just after we had moved into our house, where the only power tools I had access to were a jigsaw, and a cordless drill.
Use what you have, build what you can, and don't be afraid to ask for help from friends with more experience, or access to better tools. Don't be afraid to modify the design as you see fit. This is a choose your own adventure project, and the result should be what you want it to be.
Nice job on these horses and good 'ible!
I worked in a cabinet makers for a few summers and experienced SawHorse Snobbery!
Basically the guys in the next unit, veneer people, made saw horses like this. The old boys in our joinery laughed at them as they were made like yours with screws essentially taking all the weight. Our ones were all mortised and tennoned in such a way that the main strut across the top rested directly on the legs rather than having them screwed in the side.
There's no denying, that would be a stronger design and if I were making some I'd make some effort to rebate a cut in the legs so the top strut rested on something solid, but truth is, our one's were thoroughly over engineered and probably took a day to build whereas the screw together design was probably knocked up in an hour or two.
I guess its horses for courses, do you need them to last for ever or just until they've gotten a bit knicked and chopped and had a reasonable life anyway.
The guys in my joinery probably had a pride issue too. If someone came round looking at fine cabinets and saw falling apart equipment it wouldn't look so good (not that I ever saw the screw together type break in anyway).
Very functional, I'm sure they'll last all you need. No snobbery from me :)
Just thought I'd put all this in for anyone else considering sawhorses and their longevity.
But yours toymotorhead, look both strong and multipurposed,I like yours more than most.
I'm interested in that "Static load testing" you mentioned.
I agree, tools for uses and abuses. You definitely would be frustrated if you spent a day or two on the most beautifully joined saw horse just for some new kid in the shop to lay a plank on it and drill a few holes into it :)
http://i1207.photobucket.com/albums/bb468/pfred1/p1310020.jpg
It doesn't really matter what project I'm working on - I grab the horses out of the shed first. Not old fashioned by any means.
