3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The simplest bicycle framebuilding jig I could come up with...
Step 1The Frame
The Frame
The frame is built out of 8020 #1530 extrusion. I used the standard 1530 extrusion - there is also a 1530L extrusion that is a little lighter that you could probably use, especially on the adjustable beams that hold the tubes. This would make the jig a little lighter and cheaper
You could probably even build it out of the #1020 extrusion and it would be just fine.
The overall dimensions I used, which should work for most mtbs and large road frames, are 30 inches tall and 51 inches wide. If you want to build 29ers with long-travel forks, you might want to scale everything a couple of inches taller.
At the lower right hand corner the two frame beams are held together with a #4334 Inside Gusset Corner Bracket, so the lower beam is shorter - 48 inches long.
The other three corners are held together using just 16mm M8 buttonhead bolts and 8020 Double T-nuts. The beams are drilled to provide allen wrench access to the bolt heads.
Assembly is easy. Use a T-square to get each join at a 90 degree angle. Tighten it down.
You can order 8020 extrusion and parts from a variety of resellers - see 8020's web site. If you're in the Western US, I highly recommend F & L Industrial Solutions.
We'll look at the rest of the parts in the order they would be adjusted to set the jig up to the right dimensions.
1 comment
Apr 28, 2009. 12:45 AMelranathor says:
Great job, nice jig, i'm just going to have to build a similar one now!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
41
Author:drwelby
I grew up on Legos and the Whole Earth Catalog. These days: bike builder, map maker, trail sleuth.
