The Simplest Touch Switch
Introduction: The Simplest Touch Switch
HI THERE ,  I would like to say Hi to everyone here ,
I"M new to this site and this is my first ever inscrutable so bare with me ,
ok so lets get started ,
first things first the lest fun reading the legal stuff ,
here it goes , I'm am NOT in anyway responsible for any injuries or harm the you my inflict on your self ,
I may and may not own this idea just in case someone had this idea first ,
please take care when handling power tools ,
ok now that I said that we can get started ,
Step 1: The Simplest Touch Switch
ok here's what you are going to need so get your pen and pad ready ,
555 timer x1 ,
dip socket for 555 timer this is optional  ,
1.5 v led any color x1 ,
pcb board or bread your choice  ,
battery 3v / 4.5 ,
a small piece of aluminum  foil ,
Tools needed
soldering gun
lead free solder its a better for your health if there's no lead in it
glue gun is optional
Step 2:
ok here's a schematic I made to make it easier and also here's a pinout I got online ,
were only going to need pin 1 -2 -3-8-6 the rest we do not need ,
fallow the schematic ,
led + to 3 out
led - to 1 ground
8  to battery
1 ground to battery's ground
2 to touch plate
6 to touch plate
now to make the touch plate take a piece of foil and connect  it to the wire ,
solder your wire's to the right connections and your done ,
you can make this anyway you like solder it or use a bread board ,
Step 3:
and now the test run , touch the touch plate that was connected to pin 2 to turn on ,
to turn off touch the touch plate that was connected to pin 6 ,
so there you have it a simple touch switch ,
you can use more leds if you want or try connecting motors or what ever makes you happy  ,
Thank you everyone  for viewing my project  and for giving the new guy a chance ,
and yes I have more project to come soon ,
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    • Science of Cooking
      Science of Cooking
    I love this idea. Some questions: Will this work to power 3 leds 20mA 2-3v each (in parallel)? Is this practically feasible? Will it be sensitive to electrostatic discharge? Can I connect the touch wires to metal screws to make them into touch switches or do I have to use aluminium foil? Thanks.
    Simple touch sensor circuit full making video, having touch plates as finger pads
    Thanks for posting!
    Do you think I could use a 12V input?
    Your welcome GastónL8 ,
    The answer to your question is yes you can use 12v input ,
    It goes by your 555 timers max input ,
    Mine can handle 12v max some others can handle 16v max ,
    I would how ever make sure your current / amps are not to high ,
    I'v never tested mine above 2 amps before ,
    Hope this help answer your question
    Best Regards Tech savy
    how to connect this simple touch switch with arduino uno?? pliss tell me... because i want to build a safe deposit box...and i used this simple touch switch and then i connect to a solenoid to lock the deposit box...plis reply.thanks
    Hi Husainjr , the best way I know would be hook pin 1 and 3 to your solenoids ,
    I'm not a 100 percent sure since I don't have arduino uno I'm planing to get one ,
    wish I could help you better but since I don't use arduino ,
    my best suggestion would be to read some of the other arduino uno users projects ,
    there's some good projects to look up I'm sure they will help you find a way,
    if you need any other help i'll do my best to find the answers ,
