loading
loading
The single most effective way to get rid of a sunburn
Featured
Picture of The single most effective way to get rid of a sunburn
Well this is my first instructable, and is only going to be short because its an extremly easy and effective method to removing a painful sunburn. This method was recommended to me by my friends mother, who is a nurse and therefore MUST know what shes talking about. Turns out she did. I hope this helps many a painful sunburn to receed or dissapear.
Step 1: Gathering materials
Picture of Gathering materials
You will need a total of five things.
1)A bathtub to do this in (preferably ceramic, so it wont stain)
2)A pitcher
3)A rag that you dont mind getting stained
4)Water
5)Three bags of black tea (I use Earl Grey)
Step 2: Fill the pitcher
Picture of Fill the pitcher
First things first, strip down, because you dont want to get any of your clothes wet. Fill the pitcher with warm water and soak the tea bags in it. When you have the water almost black, like the picture, then move on to step 3.
Step 3: Healing the wound
Picture of Healing the wound
Once the water has cooled to a warm/lukewarm temperature, dunk the rag into the tea, and dab it onto the sunburn. DO NOT WIPE IT OFF! Leave it on and let it be absorbed into your skin. Once its dry, re-apply as necessary, but never wash it off. If you do this process before bedtime, you can go to sleep and give it time to work its magic. In the morning you can wash it off in your shower. The sunburn should be substancialy subsided or all gone, but remember: the sooner you can apply the tea after you get the burn, the quicker and more effective it will be.
Note: I had a severe sunburn and I also used the tea bags straight up, dabbing them directly onto my skin. You may use as many "coats" of tea as you want, but the more the better.
1-40 of 431Next »
THE NURSE7 years ago
Please DO NOT take hot showers after a sunburn. This is a BURN and hot water can make it worse d/t nerve ending damage, u can't really tell how hot the water is. Cool water helps bring down the temperature of your skin. The tannic acid in the tea bag soothes the skin; this is a great remedy for any 1st degree burn. If you suffer a really bad burn seek medical attention, please!! Dehydration/burned skin is serious and u may need fluid replacement. Tea bag treatment is also great for itching burning feet!!!!
tannins are in tea not tannic acid
drpepper8412 (author)  THE NURSE7 years ago
Thank you very much for this! Im glad that you posted this so people now understand how dangerous some of their other methods are.
FYI, if you can afford to use a whole bag of family tea bags and you have a deep garden tub like I do, then steeping the whole box in a hot bath and climbing in when the water becomes tepid is a great way to do this. Lay in the tub for at least an hour.
Today was hell for me. I had the worst sunburn itch. If you don't have blisters and your sunburn itches, a warm/hot shower works. Make sure the temperature isn't so hot as to burn you, but after the shower, the itch will be gone. I know because this just happened to me. Also of course, Aloe Vera and cold showers are good too.
jrh1436 years ago
I just tried this remedy on a two-day-old lobster belly, and WOW! what a fantastic difference! Only difference: I didn't have earl grey tea, so I used what was on hand, which is plain old Lipton ice tea bags. I used seven of the small (not family size) bags. I got almost immediate relief from my constant itching, which was making me think I was going to lose my mind (assuming I had something there to lose in the first place). I have posted this remedy to another site (wiki answers, I think) with credit given. Thank you very much for your helpful advice!
drpepper8412 (author)  jrh1436 years ago
Wow, thats wonderful! I'm so pleased that it worked that well, especially on an old burn! Could you send me the link to where you reposted the remedy?
Just wanted to add that this remedy did NOT keep the burn from peeling. I currently look like a two-toned leper. I am still quite pleased with the instant itch relief this remedy gave me, but does anyone out there know how to keep burnt skin from peeling? Seems like I never go from honky white to tan without passing immediately through bright red and then peeling back to honky white + 1 shade darker. If I find the answer to this question "out there" I'll come back and post it here. Thanks again!
JoshuaW7 jrh1432 months ago
Stay as hydrated as possible in the sun (no alcohol or coffee), use skin lotion (not sunblock, i use shea butter..). If you know you're really pale or burn easy, spend less than 2 hours the first day.
Then finally..... take an ice cold bath (preferably as soon as you are out of the sun) to draw the residual heat from your dermis and epidermis. Moisturize, and sleep.
I also use Shea butter. It works wonders.
olive oil... not only does it heal the redness and pain overnight you won't peel. After a shower put olive oil on the burns and leave overnight.
Olive oil on a fresh burn will keep the heat in the skin. This will cause the burn to get worse, because your now cooking yourself slowly in olive oil.
That is the truth!
You are thinking of a reference to an old wives tale of butter. Olive oil contains Omega 3 which is an anti inflammatory.
really that is not the case it really helps you heal - If I was slowly cooking myself it would have gotten worse- which wasn't the case. Next morning- no redness, no pain, no peeling. I lived next to the beach, I use it all the time.
Olive Oil is WONDERFUL for so many things!!! I just answered another comment on this same page, discussing how I used tallow for a poison ivy episode this last fall and I mentioned Tallow was one of the things I used for relief. But in fact, in addition to the tallow, I discovered that the ONLY things that felt good to heal the itchy blisters from the poison ivy were NATURAL substances - the NACV, Olive Oil, lamb tallow, raw honey, magnesium oil, coconut oil, bathing in epson salts (magnesium), that sort of thing. I will definitely have to remember to use olive oil if I ever get sunburned again out of my own stupidity. (oh and frequent applications of coconut oil help PREVENT sun burn. It's only got a SPF of like 3 or 4 but it does protect when applied frequently!!).
Our family has used a solution of 1 Cup cheap white vinegar to 1 gallon of cold water. Take soft rags or towels and put repeated cold compresses on the burned area. This is the most effective way I know of to keep a sunburn from peeling.
When I was young, my sunburns use to peel. Now, I use a aloe vera after sun lotion. Banana Boat is good or a store brank is ok too. Also Aloe Vera Gel helps cool the burn.
Sorry - My last experience with Banana Boat 50 SPF was a complete burn fest in Hawaii. Three full coatings and my whole family still looked redder than a sunset reflecting off a freshly boiled lobster. I used 100 SPF for the rest of my trip and many coatings of Eucerin for dry skin just to stop the burning. And yes, I peeled - the top of my head, my legs, my arms and my shoulders.
However, I don't ever expect any home or professional remedy to prevent peeling. I have used cider vinegar (and black tea) before to relieve the pain, but it too just helped to kill the skin off, for it to peel away later.
Since I burn easily and often (they really don't let me outside much) I will test each of these remedies (minus my previous experiences) and see which do not peel afterwards. Tallow/lard/butter actually sounds the most likely to succeed. One of my friends uses buttermilk to protect his leather upholstery in his car - and he's a competition judge for auto shows. I don't plan to try buttermilk on my skin though - it'd be too thin.
I do not subscribe to the "don't use oil it will fry your skin" philosophy. Our bodies secrete oils just to protect our skin and trap in moisture. It may not let your skin cool down as easily (evaporative effects are blocked) but that moisture won't be lost to the air, it will replenish the skin cells instead.
boocat jrh1438 months ago
Lovely. "Honky white"-- really? Come on. What ever happened to "celebrate diversity"? White skin is not ugly.
pcanywii jrh14311 months ago
Take a band aid and take an Aloe leaf and squeez the gel out. Especially if it is dead because it is liquid. Put it on and it's comfortable... Just what a friend said.
aloe is a liquid they just make it a gel
Real aloe comes from the Aloe plant as a thick gel.
When I had my super bad sun poisoning episode in my visit to SoCali (I'm a flatlander normally, hundreds of miles from a beach!!), the school nurse did use raw aloe vera - sent several of the leaves home with me to apply as needed. I had burns and blisters over all my back and upper legs and back of knees, prolly 50% or more of my body so A) didn't really have a way to get the aloe carefully applied to my back and was at the mercy of fellow dormmates and b) once the aloe dried, I had to go soak in the shower to reactive the aloe gels still remaining. We also found Fruit of the Earth brand of 100% pure aloe at the drug store and had the same issue, that I had to "reactivate" it, or like put more water on it so the gel would rehydrate and then feel good again. When the gel dries, it pulled on my skin and hurt again. So it was kind of a mix bag of success and additional pain. I'd have no problem doing it again now if it was smaller patches of skin where I can easily moisten it to keep the aloe working. And yes, from the plant, it was a thick gel - from the drug store bottle it was a bit thinned down but still would dry out...
msdrpepper jrh1439 months ago
Hey, it's like 6 years later, but recently I read a blog that discussed sunburn healing without peeling. I have avoided being sunburn in recent years (after the most awful sunburn during spring break 1980 in SoCalif where I literally had blisters and sick to my stomach and school doctor diagnosed it as "sun poisoning")... but this blog discusses Natural Apple Cider Vinegar (NACV) rather than tea bags. However, I've used both NACV and Tea bags for the minor sunburns that I occasionally still have and it does work. The main difference in this blog is the use of lamb tallow (which the blog discusses where to obtain, although I have also found it online at Amazon) as the additional step to prevent the peeling. I have not done that for sunburns - since I have avoided sunburns for the most part, but I will tell you after last fall's episode with poison ivy outbreak, the tallow I had was the most soothing and healing product I found on my poison ivy blisters. So... be careful with the sun, but if you've overdone it, here's a blink...(oops, blog link - so I guess "blog" plus "link" equals "blink"? except we already use blink to describe whatwe do with our eyes. Whatever!).
Here's the link:
http://www.foodrenegade.com/how-heal-sunburn-24-ho...
hopefully this helps!! and be careful in the sun!! We do need some sun for Vitamin D but do it in 10-20 minute increments in the morning before 10 am or afternoons after 4 pm! (I know, I know, it's easier said than done, especially when you are having fun at the beach, pool, lake, playing volleyball, whatever!!). :)
tovey jrh14311 months ago
The skin is peeling because it is dead.
If you want to prevent peeling, you have to prevent the burn to begin with. The best way to do this is with a long sleeve shirt that you keep handy. When you start feeling the sun on your skin feel hot, to the point that you may burn, you have to put the shirt on for a couple of hours. While this is not the best way to keep cool on a hot summer day, it is the best way to keep from burning.
I did this one year while working at a camp because I didn't want to deal with getting sun burned to begin with. When I went down to Florida that same fall, I was actually darker than many of the Floridians I came into contact with.
You could try lotion with Aloe Vera in it, but at this stage of the game, I don't think you can avoid the peeling.
smunoz5 jrh14311 months ago
If you put ice, and half vinigar, half water into a wash basin. Grab a soft wash cloth or hand towel. thoroughly wet the towel wring it out mostly and drape it over the sun burn. when u remove the towel it will be super hot rinse it in the basin again and reapply. this usually turns the sunburn into tan without peeling, but it really depends on how bad the burn is. Either way its instant relief. also make sure when you are done using the vinigar and water that you moisturize your skin.
The best I've been able to do to keep a burn from peeling is to slather it in Oil of Olay type moisturiser (Mal-Wart's Equate brand works just as well). Every time the toasted skin starts feeling or looking tight, hit the moisturiser until the skin won't take any more. You'll be vaguely sticky for a couple of days, but if you've kept the skin well hydrated, the peeling should be minimal. Of course, if anyone's got a DIY method with comparable results, I'm all (slightly pink) ears. ;D
Sure! It is at: http://wiki.answers.com/Q/What_do_you_do_when_your_sunburn_starts_to_itch
Mine is currently still the last one on the page, signed John Hance. Thank you for the helpful tip! It is one I will be handing down to my kids and passing on to all my family and friends.
I've been on instructables for a few months now and it took a wiki answers site to send me to this... and right when i needed it... my girl thinks i'm addicted but this site really does have a bit of everything.
My dad thinks that I should sip using this website cause I'm addicted to video games and he thinks I'm researching video games, which I am!
drpepper8412 (author)  TorinMiasma6 years ago
Glad you found it! Once summer starts up, I always tend to get a lot more comments, so I'm glad it could help with one of the first burns of summer!
cindi594 years ago
I did this last spring when I forgot to put on sunscreen while gardening. I wasn't burnt to a blister state but was uncomfortable on my shoulders to sleep! I made 4 bags of plain lipton tea in a glass two cup measuring cup. I let it cool and started by dipping a washcloth in and after wringing (not completely, just to not drip) it out I dabbed. Instant difference! I was able to cool the burn enough to sleep. I left the tea in the cup and in the middle of the night when I got woke up in pain I did it again. The next morning the majority of the sunburn was gone. I did use the tea on the more burned part over the next day. Instead of days of soreness, I had one! My kids have done the same since! It isn't a cure of course but It sure helps!
sickdog744 years ago
It worked for me! Here's what it did: I used 4 tea bags (earl grey) in a large tea cup. Microwaved the 4 bags with water for 2.5 minutes. Let cool, swish around. You now have a very very very strong cup of tea. Dabbed on my sunburned face. Repeated every 45 minutes or so until bedtime. Probably did it 8 or 9 times before bedtime. In the morning, I was tanned but not burned! I went from lobster red to tanned in 12 hours!
drpepper8412 (author)  sickdog744 years ago
Congrats! I'm so glad it works so well for so many other people! =D
I got a sunburn on my shoulders today and can't seem to get rid of it (because I don't know how)
Does this actually work/happen?
gaylaciad15 days ago
this better work because I have a PAINFULL sunburn on my ENTIRE backside, like the ENTIRE back side and I have to lay on my front side and being a girl that's kinda hard to do :/
I have found the most effective cure to be Lavender essential oil. Works best when mixed w/Sandlewood essential oil, but can be used alone in my experience. Put it all over the burn asap, and again first thing next morning. You burn will turn to tan, with little or no peeling. And you smell great!
1-40 of 431Next »
