Introduction: The Smallest Paper Plane on Instructables.
Picture of The Smallest Paper Plane on Instructables.
Now Kiteman may have just posted his but...
Mine does happen to be smaller, like his the version shown is made from cigarette papers, except I used longer ones.
This plane will work with newspaper and very well with receipt paper since I designed it in work...
Step 1: Get Your Paper...
Picture of Get Your Paper...
One king size cigarette rolling paper, these are swan ones, however ask if they have silver Rizla paper, this is the lightest paper sold in most shops, perhaps too light for this design...
Step 2: First Fold
Picture of First Fold
Simply fold it in half lengthways.
Step 3: Second Fold.
Picture of Second Fold.
Fold the sides down in to triangles, like the picture, make them as even as possible, they should meet directly at the tip, the plane wont fly properly unless these are perfect...
Step 4: Fold Three.
Picture of Fold Three.
This one is a repeat of the last on the new triangles, again these will need to be even.
Step 5: Fold Four.
Picture of Fold Four.
Now squeeze the plane flat and smooth the main folds down in preparation to fold the wings.
Step 6: Fold Five.
Picture of Fold Five.
Now we fold the wings out, they come out at around 35-40o from around half way down the body, if that's too confusing look at the final images of the plane and the picture below...
Step 7: Final Fold
Picture of Final Fold
On the outer edges of the wings at the front make a little fold up of a few millimetres, this is important as it makes the wings rigid and keeps the plane from flopping in the air.
Step 8: Flying It.
Picture of Flying It.
This plane requires a gentle touch, hold it in between the index and thumb, throw reasonably slow and a shallow downward angle, it should glide along quite nicely, if you're doing it from low down, throw it a bit fast and almost level, it should gain height on its own.
If you throw too fast it will simply throw itself in to a tumble, it's a mix of a dart and a glider.
Not sure about the folding technique I use, it helps give paper planes a lot more nose weight making them harder to stall.
On a final note if you want to make it smaller again you can slice the tails of the wings level with the back of the body, it will be slightly less stable but will be tiny...
DEEJAY642 (author)2015-07-07
Get off i could make one under half the size and with normal paper!!! You can even see the photo below and everyone knows the camera never lies.
bowmaster (author)2008-10-18
What are the measurements of the paper? I am not old enough to buy cigar paper.
necropolian (author)bowmaster2009-04-28
in belgium, i (13) sure don't have any trouble with it. because the paper isn't the actual cigarette! and it's very, very cheap. (i had 200 for half a dollar)
Oh not sure, use a receipt instead, it's pretty small, I don't have any to hand to measure for you, I'll check at some point though.
Flumpkins (author)2008-08-15
Smoking is bad for you
Thanks for the other comment, the papers are used for their super lightness, the 'ible has nought to do with smoking, try receipt paper or the other suggestions I put for the 'ible...
Okay!
Anyway, I'll try it later, but looks good! 5/5 + favorites
Kiteman (author)2008-08-05
Cute, but I think mine's smaller.
(No, I am not going out to the shed at ten at night in the pouring rain to get the cigarette papers to check!)
killerjackalope (author)Kiteman2008-08-05
I checked out the scaling, I'm pretty sure mine is the smaller one on the whole, however it's a bit longer...
Hah, only drizzling a bit here...-
Pfffft! I got you both beat! :P
When I was younger I made a plane out of a piece of paper that was about 1/8 in by 1/8 in. I never was able to repeat the design.
The picture is just to show it's approximate size. It might have been smaller, and it didn't look like this.
Lftndbt (author)Spl1nt3rC3ll2008-08-06
Right back at 'cha!! C'mon, who's next... this could be fun!!
Flumpkins (author)Lftndbt2008-08-15
WOW!!!
Lftndbt (author)Lftndbt2008-08-06
It "flys". If you drop it straight down, it catch the wind and projects it self forward. Not very effectly I might add yet still flys.
corey_caffeine (author)Lftndbt2008-08-14
i can make paper cranes the size of the circle of the spring from a clothes pin
Lftndbt (author)corey_caffeine2008-08-15
He he , so can I. ;P
n8man (author)Lftndbt2008-08-08
Do not make me enter this contest for I will surely beat you
Lftndbt (author)n8man2008-08-08
Oh, that's just by folding with fingers. I can fold much smaller than this with tools. Bring it on!!
n8man (author)Lftndbt2008-08-09
Ok then... *takes out microscope* and clicks on link
It has to fly though, the two we have here do, I reckon I could make it even smaller though, with flight, this versions a little light on it so there's room to play with...
Oh but it did fly! Although not in the literal term, unless a parabolic nosedive is considered flying. :P
Well this one can almost be graceful...
I see...
Let me rephrase that last sentence: rapid parabolic nosedive. I can't make a flying paper airplane if my life depended on it.
i've made fortune tellers even smaller than that. (used toothpicks instead of hands)
AnarchistAsian (author)2008-08-05
ciggarette paper? at work? how old are you?
i see...
About This Instructable
3,678views
8favorites
License:
Bio: A Northern Ireland based maker with a propensity to cause trouble and freshly constructed family.
More by killerjackalope:Stroboscopic ZoomographyBalsamic Chilli Sweet Potato FriesWire Belt Hook for Drills
Add instructable to:
