3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The two greatest pranks ever
These are great pranks that will for sure make you laugh but not the victim.
Step 1The Sink Prank
The Sink Prank
First, you will need duct tape matching your sink's color, a sink with a sprayer, and glad wrap.
           Okay, so make sure everyone in your house is asleep. Next, go to the sprayer and put a small amount of glad wrap on the nozzle of your sprayer. Then, duct-tape the sprayer notch to ON.
THE EFFECTS: A decent alarm-clock and a pissed off sister with plastic on her neck and a completely wet shirt.
11 comments
Mar 20, 2012. 4:04 PMflyingchainsaw says:
Dear Friends:
This is to clear up previous comments,
-No, one cannot be shocked by putting a paperclip in a toaster, for
you are not grounded. You are only touching one half of the circuit.
-No, it's probably not smart to put a paper clip in a toaster. You could
get burned.
-And finally, the idea of the hot paper clip is to make a dent in the quarter,
not go all the way through it.
please read the full instructable BEFORE making a comment.
Thank you.
Oct 9, 2011. 4:39 PMAvasar10000 says:
YOU CAN NOT POKE A HOLE THROUGH A QUARTER USING A HOT PAPERCLIP!!!!!! AT BEST, THE COPPER OF THE QUARTER WOULD ABSORB THE HEAT (AND THAT IS IF YOU EVEN GET THAT FAR WITHOUT GETTING SHOCKED OR BURNED). THIS WOULD BE STUPID. I AM SORRY FOR BEING HARSH, BUT USE SOME COMMON SENSE YOU WILL GET SHOCKED OR BURNED, MAYBE BOTH. DO NOT TRY THIS METHOD!!! INSTEAD, SIMPLY CLAMP THE QUARTER IN A VISE AND USE A DRILL WITH THE APPROPRIATE SIZED BIT......AND WEAR SAFETY GLASSES!!!
Jan 12, 2012. 7:06 PM2xlbu4u says:
I think a car battery and a coat hanger might do the trick. Place the quarter on the negative terminal, hook the coat hanger around the positive terminal and then use the pointy part to pop the hole. You might want to wear some dark sunglasses...
Oct 7, 2011. 12:26 PMwhit8965 says:
yes good
We (my two brother & I) would rubber band the handle on our old waterpick. It was pluged into a wall socket controlled by the wall swich. My dad would get up very early for his job would go into the bathroom turning on the light and "WAM" INSTAND AMBUSH. He was realy cool about it he would wake us with wet hands prior to leaving for work. God how I miss him.
Let be known, every once & awhile mom would be caught in the trap. She was not so much fun for the day. But hey we were kids and learned early cause & effect some good some not so good.
Good times
Jul 4, 2011. 4:07 PMjacobj says:
@VailMilitia if you stick even the tip of a paperclip or anything metal in a toaster you could die.
Mar 31, 2011. 8:00 PMWascopirate says:
if you touch the coil on a toaster with metal you get shocked. thats why toaster tongs are made of wood
May 8, 2010. 7:26 PMsuperjail3 says:
 how do u poke a hole through the quarter?
Mar 20, 2011. 11:23 AMGDParduhn3 says:
YOU D ONT PUT A PAPER CLIP IN A TOASTER !!!!!!! PERIOD !!
THAT MUST BE THE JOKE RIGHT ??
BECAUSE A PAPER CLIP CANNOT PIERCE THRU A QUARTER !!!
HA ! HA !
Jul 6, 2010. 10:47 AMsuperjail3 says:
ty for answering didnt think u were anyways cool ill try it but one other question why would u put a hole in the quarter
May 13, 2010. 9:00 PMRelientOwl says:
You can also just use a rubber band and tie it around the handle same effect
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:VailMilitia
