The two greatest pranks ever
 by VailMilitia
These are great pranks that will for sure make you laugh but not the victim.
Step 1: The Sink Prank
First, you will need duct tape matching your sink's color, a sink with a sprayer, and glad wrap.
           Okay, so make sure everyone in your house is asleep. Next, go to the sprayer and put a small amount of glad wrap on the nozzle of your sprayer. Then, duct-tape the sprayer notch to ON.
THE EFFECTS: A decent alarm-clock and a pissed off sister with plastic on her neck and a completely wet shirt.
Step 2: The Quarter Trick
You will need:
- A quarter
-A busy sidewalk
-A toaster(optional)
-A paper clip(optional)
-Epoxy or some kind of crazy strong glue
             First, go to your sidewalk with your glue and quarter. Simply lay down a thick layer of the glue and put your quarter on it. Now for the toaster and paper clip. (This is totally optional) Put the toaster on high. As soon as the bars at the top of the toaster turn orange, rub the paper clip on it so that that is red too. Then poke a hole in the quarter to make it look like a gag quarter.
sanjorick says: Sep 27, 2012. 7:12 PM
Take a sewing needle a bar of soap and a silver coin.Place the needle through the bar of soap,place on a wood platform and you can nail the needle through the coin.The bar of soap acts as a lubrcant. BTW has to be a silver coin. SANJORICK
jacobj says: Jul 4, 2011. 4:07 PM
@VailMilitia if you stick even the tip of a paperclip or anything metal in a toaster you could die.
Avasar10000 says: Oct 9, 2011. 4:39 PM
YOU CAN NOT POKE A HOLE THROUGH A QUARTER USING A HOT PAPERCLIP!!!!!! AT BEST, THE COPPER OF THE QUARTER WOULD ABSORB THE HEAT (AND THAT IS IF YOU EVEN GET THAT FAR WITHOUT GETTING SHOCKED OR BURNED). THIS WOULD BE STUPID. I AM SORRY FOR BEING HARSH, BUT USE SOME COMMON SENSE YOU WILL GET SHOCKED OR BURNED, MAYBE BOTH. DO NOT TRY THIS METHOD!!! INSTEAD, SIMPLY CLAMP THE QUARTER IN A VISE AND USE A DRILL WITH THE APPROPRIATE SIZED BIT......AND WEAR SAFETY GLASSES!!!
2xlbu4u in reply to Avasar10000Jan 12, 2012. 7:06 PM
I think a car battery and a coat hanger might do the trick. Place the quarter on the negative terminal, hook the coat hanger around the positive terminal and then use the pointy part to pop the hole. You might want to wear some dark sunglasses...
tech dawg in reply to 2xlbu4uJul 5, 2012. 8:44 PM
Lol
flyingchainsaw says: Mar 20, 2012. 4:04 PM
Dear Friends:
This is to clear up previous comments,
-No, one cannot be shocked by putting a paperclip in a toaster, for
you are not grounded. You are only touching one half of the circuit.
-No, it's probably not smart to put a paper clip in a toaster. You could
get burned.
-And finally, the idea of the hot paper clip is to make a dent in the quarter,
not go all the way through it.
please read the full instructable BEFORE making a comment.
Thank you.
whit8965 says: Oct 7, 2011. 12:26 PM
yes good
We (my two brother & I) would rubber band the handle on our old waterpick. It was pluged into a wall socket controlled by the wall swich. My dad would get up very early for his job would go into the bathroom turning on the light and "WAM" INSTAND AMBUSH. He was realy cool about it he would wake us with wet hands prior to leaving for work. God how I miss him.
Let be known, every once & awhile mom would be caught in the trap. She was not so much fun for the day. But hey we were kids and learned early cause & effect some good some not so good.
Good times
Wascopirate says: Mar 31, 2011. 8:00 PM
if you touch the coil on a toaster with metal you get shocked. thats why toaster tongs are made of wood
superjail3 says: May 8, 2010. 7:26 PM
 how do u poke a hole through the quarter?
GDParduhn3 in reply to superjail3Mar 20, 2011. 11:23 AM
YOU D ONT PUT A PAPER CLIP IN A TOASTER !!!!!!! PERIOD !!
THAT MUST BE THE JOKE RIGHT ??
BECAUSE A PAPER CLIP CANNOT PIERCE THRU A QUARTER !!!
HA ! HA !
VailMilitia (author) in reply to superjail3Jul 5, 2010. 11:17 AM
Sorry it took so long to reply, but you stick an end of a paper clip in the toaster. as soon as it's hot, you can use the paper clip to put a hole in the quarter.
superjail3 in reply to VailMilitiaJul 6, 2010. 10:47 AM
ty for answering didnt think u were anyways cool ill try it but one other question why would u put a hole in the quarter
RelientOwl says: May 13, 2010. 9:00 PM
You can also just use a rubber band and tie it around the handle same effect
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
