3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The ultimate guide to eco living
This Instructible will show you how to live greener with some tips ranging from a small tweak in your life to a large shift.
Step 1Living Green
Living Green
Green living can be a small change that barely effects you, or a complete lifestyle, but implementing just one of these changes completely into your life can have a big impact on the environment.
**If anyone has something that they have heard that I have missed, then PM me or write it in the comments. I will try to add it ASAP**
***Please vote in the Earthjustice United States of Efficiency Contest!***
25 comments
Nov 13, 2009. 2:03 AMWesley1 says:
CFLs are BAD for the environment, the mercury in all Florescent Bulbs is bad for the environment.
Feb 18, 2012. 2:50 PMsethcim says:
If you burn coal to make your electricity, that releases even more mercury into the environment.
Jan 9, 2012. 7:59 PMdemintedmint says:
LEDs>CFLs>Incandescents
Where do you recycle your CFL bulbs? They are not accepted in typical recycling programs, but instead require special recycling because of the hazardous mercury. Most people do not know they contain mercury, or that they are recyclable, let alone how to recycle them or how to deal with one if it breaks.
Nov 15, 2009. 4:28 PMWesley1 says:
True, however LED light last much longer, use even less power, and are much better for the environment.
Dec 11, 2010. 9:24 AMXatix says:
Some of the points made in this instructable are good; but others, such as buying a hybrid and using solar panels, are not, in reality, a very effective way of cutting down of energy usage and carbon emissions as the manufacturing of these large objects is huge and overall the benefits from having them aren't as large as you may think. The main areas to target need to be those that use the greatest amounts of energy/resources. the largest users are transport, manufacturing and heating. A simple way of saving both money and the environment is to turn your heating down, and wear another jumper, cycle or walk instead of drive wherever possible and try and re-use things before recycling them as however good recycling is, it still uses a fair amount of energy.
Jacob has a good point about eating less meat, as it is a lot worse for the environment, plus it's healthier.
Anyway, thanks for posting the instructable and I hope you find this criticism constructive.
May 15, 2009. 5:24 PMJacobAziza says:
The single biggest difference you can make in the fuel use of your car is to SLOW DOWN. When you go 2 times as fast, it requires 4 times more energy. (This is why the US instituted a 55mph speed limit after the 1970s oil embargo) When you eventually buy a new car, buy the smallest one that can fit your daily needs (if you only need a truck once a month, buy a compact car and rent a truck once a month) The car which uses the least fuel is the one that is sitting in the garage. Ride a bike or take transit as much as possible.
Apr 11, 2010. 7:08 PMjj.inc says:
 Not necessarily its about RPMs if you have a stick drive in high gears at low RPMs if you have a automatic, chip it, but not for power, for low RPMs and high gears.
Apr 11, 2010. 8:59 PMJacobAziza says:
Driving in the highest gear you can without lugging (shifting early) is ALSO true, absolutely.
However, once you reach the highest gear, the only way to limit RPMs is to stay at that speed.  In the majority of cars you reach top gear between 45 and 60mph.  Which means the limiting RPMs means not going above that speed.
Which just happens to also be the speed at which wind resistance becomes a major factor, and increases exponentially as you go faster.
Apr 11, 2010. 7:13 PMjj.inc says:
 no no no
no CFL, I did an experiment, they last longer in a 24-7 environment, but under normal on off circumstances the incandescent performed best, but LEDs are the best and I don't know if they ever quit.
no solar panels, they are expensive, inefficient, and take up to much space.
Apr 11, 2010. 7:07 PMjj.inc says:
 can, up to, dude you need to worry about the minimums
natural gas car, that sounds like a big heavy tank no refueling and big explosions.
hybrids aren't that special they get energy from the grid which is still mostly coal powered, thats not green.
Apr 1, 2010. 11:28 AMTheFantastic says:
 Hybrid cars are a sales gimmick. The pollution that comes out of a cars tailpipe over it's operative lifetime pales in comparison to the pollution created to manufacture it. The perceived reduction in impact of Hybrid cars is an illusion. The batteries in these vehicles contain heavy metals and must be carefully disposed of. Hybrid vehicles are heavier and thus go through tires more quickly.
It is dust to dust impact that must be evaluated when selecting a vehicle to minimize environmental impact.
Dec 3, 2009. 8:11 AMstevepuk says:
I don't have AC and live in the UK where I would rarely need it, but I have heard that using AC can be more efficient that opening a window and increasing a car's drag. Some people are pretty obsessive about their fuel economy and you can read their thought by searching for hyper-miling.
Dec 20, 2009. 4:39 PMtheHERO says:
 You're right.  After 40 mph, (sorry I don't know kilometers) it's more efficient to use air conditioning rather than having the windows down!
Oct 15, 2009. 9:29 AM_Scratch_ says:
seems almost everyone horribly fails to realize that CO2 is heavier thanair.......HOW THE HECK DOES IT GET IN THE OZONE LAYERPEOPLE?!?!?!? also the massive forests and greenery of the world willfilter most of the CO2 out of the air. it is only a moderate healthconcern if you live in a large city, where there is not much greenery toabsorb CO2. i have no clue why people are worryed about global warmingwhen there and temperatures that are 40 degrees below average in the U.S
Jun 19, 2009. 12:04 AMA good name says:
3 steps? You call this ultimate? 3 cliched steps? 1/2 star.
May 15, 2009. 5:21 PMJacobAziza says:
A couple of small things for the misc list: -Dry clothes on a line instead of the dryer. -Use rechargeable batteries. -Turn your computer off when you are not using them and set it to go to stand-by mode on its own after a few minutes in case you forget.
May 15, 2009. 5:09 PMJacobAziza says:
Excellent, but, you forgot one really major one: Eat less meat. The production of meat takes up to 10 times as much water, land, energy, and pollution, as the same amount of calories from plant sources. On average, most American's total impact on the environment from driving a car and diet are close to equal. You don't have to go vegan right away. Just cutting back helps.
May 14, 2009. 8:29 PMGEEK1 says:
great! but opening windows is more efficient than ac below 40 mph but above 40 mph ac is more efficient.
May 13, 2009. 7:08 AMcreator 1 says:
great instructable! Might be a slight error in step two. Um, you more than likely want to buy a car with high mileage, not low mileage. More miles the gallon. again, great instructable. <>< creator 1 {got my vote}
May 13, 2009. 7:48 PMcreator 1 says:
no problemo
May 13, 2009. 3:37 AMwsround says:
When you post something as "The Ultimate Guide" I think it should be a bit more than vague you should do this listing. How about some specific examples. I read the list, and that is all it is a list, "Donate your clothes" Ok thanks what would I do with them and how does that qualify as ultimate guide on going green. Recycle batteries great idea where and are you talking all batteries or just rechargeable there are differences in what you need to do with each. I just picked a couple here but I could do the same with all of them. I am not trying to be harsh but I see "go green" postings here and other places and I for one would like more specifics.
May 11, 2009. 6:30 AMiPodGuy says:
- Put a jacket on your water heater.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:magicentral
