3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The ultimate, heavy duty, stackable, bullet proof, extreme saw horses!
Step 13Trimming the braces
Trimming the braces
  • last photo ←
I'm sorry I cannot give you a hard number to which to trim the braces. As I mentioned earlier, the GDF warps all over the place, and I am only a mere human and have not assembled all of the legs perfectly. Hence the need for custom fitting of the braces.
My original idea was to install the braces and then use a router with a flush trim bit to cut them off. Unfortunately I did not have a sharp enough bit and had to modify my plans.
Here's the real deal...
Set a saw horse up on its legs on the work bench. Gently lift it straight up and tap the legs to insure it is sitting flat and level.
Take a scrap piece of 2x6 and lean it against the legs on the end of the horse. Draw a line on the legs at the top of the scrap 2x6. This will indicate the bottom of the brace.
Set the brace on the 2x6 and mark the legs at the top of the brace.
On the side of the brace touching the legs, mark the angle of the legs.
Square up your table saw blade to 90 degrees.
Pivot your miter gauge to 15 degrees. Make sure you have a long enough fence to support the length of the brace to the left side of your blade.
Depending on the direction you turn your miter gauge; you will have to transfer one of the lines from the front to the back of the brace. See pictures for clarity.
Using the miter gauge and table saw, trim both of the ends of the brace to 15 degrees.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
18
Author:Mikey D
I teach High School Welding and Video Game Development (currently) and have taught everything in the Industrial Technology area. I also currently teach Welding at the Community College. I love des...
more »
