3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The ultimate workbench top!
  • last photo ←
Using cheap mousepads makes for a low cost, VERY easily repaired, handsome and comfortable workbench!
Step 1The problem
The problem
Workbench tends to collect damage from soldering iron, gunk from old radio innards, x-acto cuts and so forth.
32 comments
Jan 1, 2011. 7:23 PMtackdetack says:
I love how your mouse is on a mouse pad on a mouse pad!
Dec 22, 2010. 12:01 PMkadeishasims says:
Another idea would be to make a gelatine.you know the stuff the mythbusters use as a dummy for trying out guns.it takes the form of human flesh.make a few pans of it and lay in on your workbench.look up on YouTube or google it for the recipe
Oct 18, 2010. 8:56 AMChris Modified Lted says:
Thank you. Pads are a good idea!
I showed my gf the "Who needs to clean off the bench to repair it?" note. Still sceptic but a good +1 for me.
Apr 2, 2009. 3:24 PMxproplayer says:
im no expert but oculdnt u just use the rubber bottom and not glue it that is what it is designed for
Jan 20, 2009. 9:40 PMrightbraincreative says:
I work in a print shop and sometimes take home the press "blanket" after it is changed on the press to cover my workbench. It is essentially a rubber mat with a degree of self healing properties. It will be pretty ugly after it's been on a press for a while, but is very durable. Ask your local print shop to save you one. Thnks for the 'structable
Aug 22, 2008. 9:58 AMPhil B says:
Another idea for a soft surface that will not damage polished parts and offers a constantly renewable surface is an old telephone book. Rip off the front cover. Anytime the top pages are torn or soiled, just tear them off and you have a new surface.
Jan 20, 2009. 7:10 PMDYLEGO says:
There may be a cough small cough fire hazard involved... Plus the surface won't be even if you combine multiple books...
Jan 20, 2009. 8:43 PMPhil B says:
This was a suggestion a number of years ago from Popular Science or Popular Mechanics. The object was not to cover an entire table surface with old phone books, nor was the object to use old phone books near any flame or heat source. The object was to have a soft, clean surface always available for delicate parts subject to destructive scratches. An old phone book makes a very good surface for rebuilding a carburetor, for example.
Aug 3, 2008. 11:39 AMrob.price.3 says:
Great idea. you can get the same material but in a large sheet form for about $10.00 from rubber or industrial supply or gasket house. I looked at my mousepad and it is made from 1/16 thick #3120 open cell neoprene sponge. I used to make mousepads as a kid. Since someone else used a mentioned a company, I will too: www.murdockindustrial.com Your mousepads looks like they were made from 1/16 thick SC42 closed cell neoprene sponge.
Jan 20, 2009. 7:57 PMDYLEGO says:
Do you think matbe you could remove the extra pictures at the beginning? I can't rate it... Usually that happens when there are so many pictures that it covers the "related" section... I want to give you 5 *s, but, well, I can't...
Aug 31, 2008. 1:20 PMpuffyfluff says:
Hmmm... Useful.
Aug 29, 2008. 6:13 PMcodongolev says:
coolio!
Aug 10, 2008. 10:44 PMrecynd says:
You, sir, are the greatest. Ever.
Aug 8, 2008. 6:40 AMdpocius says:
I like the "tile" aspect whereby you can renew the benchtop without having to remove absolutely everything. I've screwed a 2' x 4' piece of 1/4" thick of MDF (medium-density fiberboard) to the front-center of my 8' x 3' benchtop to take the beating from the boat anchors I typically work on. I also have an antistatic mat I lay down on top of that for more delicate work. The MDF is easily and cheaply replaced, with the old piece typically recycled for some utilitarian use.
Aug 7, 2008. 5:51 PMCoffee bean says:
cool but can you right on it well
Aug 6, 2008. 9:09 AMchalky says:
genius!
Aug 5, 2008. 5:06 PMakira45 says:
totally awesome, right now I have a small (like 2'x4'4") computer desk I'm using for some electrical work (modding r/c cars, fixing neighbor's dvd players etc.) and I've been wondering how to fix the problem of stuff rolling around and bouncing screws and whatnot! this looks like a great idea to solve that problem, plus all the pros previously mentioned. much kudos!
Aug 2, 2008. 7:34 PMT-K says:
That is pro. I use a self-healing mat, you know those green ones, but this is probably cheaper.
Aug 2, 2008. 11:59 AMszechuan53 says:
cool. comfy. cheap.
3 c's=good workbench top.
Aug 2, 2008. 11:53 AMegreen767 says:
awesome! I think it's kinda funny that you use a mouse pad for your mouse on top of a mouse pad covered table.
Aug 1, 2008. 10:31 PMtechnodude92 says:
Awesome, original idea! 5* and fav'd!!
Aug 1, 2008. 6:07 AMLlewner says:
For a more durable solution, you might try a self healing cutting mat from Denver Sign Supply. It will cost a bit more, but it should outlast SEVERAL changes of the mousepads.
Aug 1, 2008. 1:23 AMMark Rehorst says:
It's a nice idea, however, you won't get any static discharge protection this way. Much better to invest in an antistatic mat that covers the bench and get a wrist strap that plugs into the ground connection on the mat. If you work with any semiconductors you'll save a lot of time and heartache by properly grounding yourself and the bench. Get a grounded soldering iron, too.
Jul 31, 2008. 9:05 PMMr. Rig It says:
Cool idea, nice use of materials and lots of great photos, Good Job.
Jul 30, 2008. 1:58 PM=SMART= says:
Original Idea !! , i think i would use the plastic side though so it is wipe-clean
Jul 30, 2008. 4:21 PM=SMART= says:
Actually yes you are right, the neoprene side is wipe clean and it has the added grip too
Jul 30, 2008. 1:38 PMuguy says:
Cool idea!! Thanks for sharing.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:poptones
