3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The ultimate workbench top!
Step 3Removed the damage
Removed the damage
After much tearing, the surface will finally look like this.
Again, this all tore the way it did because I use wood glue on plywood. I do this because this is the primary surface of my bench and I don't care - but believe me, it works just as well using white glue on nicer tops. If you have a formica countertop, white glue with this stuff works great and it wont tear as easily. Mine usually doesn't even tear this badly, but I put off replacing it longer than usual and it was pretty badly cut up.
White glue also cleans up easily with warm water, so the next step wont be needed if you are starting with a nicer subsurface.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:poptones
