3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The universal multicolour torch (flashlight)
Step 7Adding the switch and the resistors
There was not very much space left in the head of my torch, so I soldered the single resistors directly to the contacts of the switch. Because the infrared LEDs need a separate resistor each, I put them on a small circuit board to keep the chaos limited.
The 12 position switch has a small ring attached with a pin that can be placed into a series of holes, allowing to limit the switching positions. I used this to set the switch to the 6 positions that I needed.
To fix the switch within the torch head I used a glue gun which worked suprisingly well. Just be careful not to glue the shaft.
Finally I soldered the wires to the LED circuit board.
After reassembling the torch it showed that all LEDs were working perfectly!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:duesentrieb
