Introduction: The 'whats in My Bag'-bag
The 'whats in my bag'-bag
Step 1: The Idea
For the elective Fablab making we got the assignment to create a product/object of your own liking with the only requirements to use:
- 3d printer
- laser cut machine
- sewing machine (or any other third machine of choice)
- a hinge
- a switch
The Idea
Because of the very broad interpretation of the assignment i thought it would be fun to link my project to my own discipline, which is fashion and design. It would be a nice challenge for me to create a fashion item which is not only constructed by a sewing machine but also different machines/materials than the usual. Because of the requirements i had the possibility to create a fashion item that is not just fashionable but also useful in ways it normally is not.
The 'whats in my bag-bag' is created for people, like myself, that always loses their stuff in their bags. This because of the dark materials that are mostly used in bag linings. With a small build in led light, the inside of the bag will be much easier to see.
Step 2: MoSCoW Method
To have a clear idea of what i will need to create this bag is used the MoSCow method.
Must haves:
- fabric
- plexiglass
- hinges
- bolts and nuts
- led light (+ battery, battery holder, connector etc..)
Should haves:
- button made with 3d printer
Could haves:
Would haves:
x
List of used materials:
- faux leather outside o the bag)
- synthethic mix ( lining of the bag)
- plexiglass
- hinges (+ bolts and nuts)
- led light
List of used machines/software:
- 3d printer
- lasercut
- sewing machine
- sketchup
How its made:
At first i drew a pattern for the bag. I wanted it to look very modern, minimal and edgy, reason why i made it a square shape. After that i drew a pattern for the bag handles in Illustrator. Like is said, i wanted the aesthetics of the bag to look very modern so i made the bag handles out of clear plexiglass and attached them to the bag with hinges. The first idea was to make a pocket inside of the bag. This pocket could have been opened and closed with a button i would make with the 3d printer. But this would make the bag look very bulky because of the large amount of fabric attached on one place. So i just made the button.
How it went:
I already used a few of the materials, machines and software in previous project. What was new for me was first of all, creating an on/off switch with press button. I already knew how to draw a simple circuit for an on/off switch with connector but that was about it. So i spend a day in the interaction station with an attendant who helped me through the process. And it turned out to be very simple. I was lucky to get all the elements i need in the station so it was a small task to put it all together. Sketchup was also a new thing for me and turned out to be a bit of a challenge. I drew a (quit complicated) button which failed drastically and also did no fit the look of my bag anymore. After this i drew a simple one and this time it was perfect! Like mentioned earlier, i did no make a pocket anymore to attach it on.
Step 3: Sketches/tests
picture 1 - sketches design
picture 2 - bag handles drawn in illustrator
picture 3 - 3d print buttons (the right one is my first attempt)
picture 4 - light circuit
Step 4: End Result
Reflection
At first i thought it was difficult to just come up with an idea without really focusing on a concept like i usually do. Like i mentioned earlier, because of the broad interpretation of the assignment it was easy to make it relatable with your own discipline. So i just started sketching a few ideas with this in mind. I wanted to create a fashion item that was both fashion and useful in a way that i and others are not used to see.
Because of the list of requirements i learned a lot of new things. For example the use of sketchup and also creating a light circuit with press button.I was glad to be able to work with different softwares and machines i normally would not use in my study. Whenever i got stuck during the process, i reached out for help in the different stations at school. The attendants and school colleagues taught me a lot.
I also think that for my future (fashion) projects i may use materials that are more uncommon, and maybe create more items that are not just aesthetically good looking but also functioning in more unsual ways. overall i enjoyed working on this project and i think my 'whats in my bag-'bag turned out rather good. It's already my favorite bag!
