The wire-less Ikea LEDstrip : gruesome green hack
Featured
Step 2: Throwing molten lead
Picture of throwing molten lead
Ok, it's soldering time.
we will connect one wire directly between battery(-connector) and the small bit of PCB. Be sure this wire is soldered in the hole that is closest to the thicker black part of the circle drawn on the PCB. see photo.
Then, the other wire from the battery(-connector) to a switch, and finally a third wire from the switch to the other hole in the PCB.
This is a standard circuit that can switch on and of power to the LED strip.
IMPORTANT : BE SURE THE BLACK WIRE OF THE BATTERY CONNECTOR CONNECTS AS SHOWN IN PHOTO to the PCB.
it is important because otherwise you would in effect connect the battery to the LED strip the wrong way round, which might damage the LED strip.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
