Introduction: There Is the Bowl Making Through the Use of Circular Saw
There is the boul making throngh the use of circular saw on the photo (the saw blade diameter is 190 mm)
Step 1:
1. You need to begin by marking two circles on the cylindrical workpiece billet.
Step 2:
1. Then you need to set the stops on the circular saw. The distance from the top of the saw blade to the stops is the diameter of the workpiece billet.
Step 3:
1. The saw blade should be below the table level. Install the workpiece billet over the saw blade and activate the saw.
Step 4:
You need to make next actions very careful. It’s dangerous. You need to raise the saw blade on the working circular saw by 1,5 – 2 mm, and then rotate the workpiece billet by 360 degrees. Repeat this action as many times as necessary to get the cavity of the required diameter.
Step 5:
Make the octagon from the cylinder.
Step 6:
Form the edge of the bowl.
Step 7:
Cut off the excess at an angle of 45 degrees.
Step 8:
You need to cover the product with the solution of linseed oil and beeswax.
The bowl is ready!
