3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Thermal test chamber for edge of space testing.
Update: This copyrighted content will soon be purged from the instructables website. I hereby revoke instructables license to this content.
Getting stuff *really* cold is difficult, dangerous, and lots of fun. Our group is preparing to send an autonomous glider up to about 100,000 feet, so we needed a way to chill our electronics to -70c to test their use before these edge-of-space flights.
Basic concept:
Just using dry ice in a cooler will result in about 0c air. In order to chill air much colder, a fan is used to circulate the air to reach -42c. In order to hit -70c or colder, liquid nitrogen and a heat exchange (coil) is used.
This test chamber uses dry ice and liquid nitrogen to cool the air.
This instructable is part of our edge-of-space project. Watch for updates over on Hackerbot Labs
Step 1Acquire parts for building
You'll need a bunch of parts to build a test chamber, along with some supplies. Here's what we used:
  • 25' of 3/8" copper pipe (hardware store)
  • Fittings to adapt up to 1/2" ID pipe (hardware store)
  • 2' of 1/2" pipe to use as a reservoir
  • Fiberglass wrap insulation for reservoir
  • Teflon tape for the threads (hardware store)
  • 4" diameter PVC pipe (just for forming the coil, about 2' will do)
  • A large ice cooler which you can remove the lid from.
  • 2" thick pink insulation foam. a full sheet is handy, but it needs to be the size of your cooler
  • A powerful fan which can fit in the ice cooler for air circulation
  • One or more thermal probes for monitoring the temp (K type thermocouples work best here)
  • A large cooler/ice chest with a lid which can be completely removed.
  • "ice" packs. The sealed kind you reuse. A bunch of them
  • A funnel
  • Some stiff plastic tubing
For operation of your test chamber, you will need the following consumables:
WARNING: This stuff is cold - so cold that it will burn you. Seriously. It can blind you. It can freeze off a finger or a limb, and I'm not even going to get into what would happen to your insides if you drink it. Use proper care while handling. Eye protection is very important while interacting with liquid nitrogen. Ventilation is extremely important as well. USE AT YOUR OWN RISK.
  • Several blocks of dry ice. 10 lbs will do, 20 is better. This can be sourced at most grocery stores. Some states require you to be 18 or older to purchase and consume Dry Ice.
  • a large dewar of liquid nitrogen. This can be sourced at most welding supply shops. Dewars can be rented or borrowed.
50 comments
1-40 of 50next »
Apr 27, 2008. 8:17 AM-Aj- says:
me likes. yeah ok, so many noobs out there that are 'leet haxor overclockers' brag about having supah dupah cooling systems at like, -30C n crap. silicon junctions work optimally around 40C .so cpu says DO NOT WANT. your electronits will get rather unhappy at cold temps especially any caps that happen to get that cold, their mystical powers of filtering disappear! so cooling to maybe, 20C would be ideal, to allow for core temps being higher then ambient and also not cold enough to cause condensation.
Aug 19, 2008. 7:51 PMguitarman63mm says:
Really? I thought the electrons flowed better at cold temperatures, meaning better conductivity, meaning better performance from any and all devices. No?
Apr 9, 2008. 12:41 PMjohnnyshaman says:
Just an interesting detail about N2 (or any inert gas I suppose) is that if it displaces most the air in the room you'll suffocate without warning and you'll die even if brought to fresh air unless the N2 is forced from your lungs. It's the CO2 that triggers your breathing reflex; you won't start breathing without it. A matainance guy died just like this at a local IBM facility when he was working in the sub-floor and there was an N2 leak. Sorry to start the urban myth, but I don't have any more details...
Apr 9, 2008. 2:35 PMlebelt says:
yup. the condition is called hypoxia, it happens when you do not get enough 02, and too much n2. you will not be able to tell when you get hypoxia until its too late.
Apr 26, 2008. 9:33 PMsky3 says:
actually, having been in a hypobaric chamber (for the reason of identifying my own personal symptoms of hypoxia, since they vary from person to person), i can say that the most common symptoms are blue fingernails, dizzyness/loopiness, and losing the ability to write. after about 3 of the 5 mins at a simulated 20k ft, i definitely knew that something was up biologically. therefore, the person educated on hypoxia can know when it's time to use an emergency breathing aid.
Apr 26, 2008. 10:26 PMlebelt says:
my knowledge of hypoxia is limited to what I learned form my Nitrox diving course, it has to do with hypoxia underwater, which is diffrent
Apr 27, 2008. 1:52 AMsky3 says:
ah, right. hyperbaric hypoxia. i do not have diving experience, so that scenario had eluded me when i commented. (oO)
Apr 27, 2008. 9:06 AMlebelt says:
hyperbaric hypoxia? its just hypoxia.
Apr 27, 2008. 11:10 AMsky3 says:
yeah, it is just hypoxia. the five hour class that i took on the physiology of humans in a microgravity environment had a teacher who described underwater hypoxia with the term i used.
http://www.google.com/search?hl=en&client=firefox-a&rls=org.mozilla%3Aen-US%3Aofficial&hs=l0V&q=%22hyperbaric+hypoxia%22&btnG=Search
you may call it whatever you like, silly. 8)
Apr 22, 2008. 2:31 PMZachPosey says:
i wonder if this thing is cold enough to cool my 360...
Apr 27, 2008. 6:51 AMforcryinoutlouddrummer says:
dude, if you try doing that you're gonna screw up your 360
Apr 18, 2008. 5:23 AMcallmeshane says:
FUN THINGS: I knew the issue of "suffocation" with "simple aspyxiants" - in low oxygen atmospheres - was a "REAL" issue, I just never understood the mechanisim. It's simple. Person climbs into tank that had nitrogen, or argon as it's covering gas (inert) over say something like food oil, or wine - and the tank is say 20' deep and the layer of gas may be 10" deep or what ever. The person gets to the bottom, feels dizzy, collapses, and then may die fairly quickly.... As all too frequently happens, some one sees the collapsed person, in the bottom of the tank, ASSUMES they must have fallen or had a stroke or something, and then climbs into rescue them.... ' They too collapse. The third person comes along...... same thing happens...... Three people died like this at either a winery in a HUGE wine tank, or it was an empty holding tank for pig manure -- filled with methane. The way (usually) "INERT" and "NON TOXIC" gases, that are almost always COLORLESS and ODOURLESS kill people is really really neat..... it's just so subtle and frequently fast. The lungs and brain are hard wired to EXHALE when the build up of Carbon Di-Oxide gets to a certain point in the lungs...... It's the CO2 coming out of your blood that makes you breath....... If your not taking any or too little oxygen into your blood, then there is no or not enough CO2 coming back into your lungs to register the breathing mechanisim. It's not the pressing need to exhale or inhale that is so much the problem, its just we have NO mechanisim, to detect and respond to any gas, other than CO2...... That's why people who climb into tanks filled with nitrogen, methane, helium or argon etc.... they never panic, they don't feel alarmed, they just feel woozy as the last dregs of oxygen in their blood gets used up and "poof" out like a light. They collapse and occassionally die - very quick and very easy.
Apr 13, 2008. 1:14 PMflee2010 says:
I noticed the person pouring the liquid nitrogen wasn't wearing gloves. Was that safety precaution just for the person holding the funnel where one might get splashed?
Apr 13, 2008. 11:33 PMplaes says:
As -200 degrees celcius might sound like something that's very dangerous it really isn't. Accidental splashes are harmless and well, we have even tried pouring some of it just on the hand. Nothing happens as it is quickly evaporating when it gets into contact with skin.
Apr 17, 2008. 9:24 PMogorir says:
Other than the fact that you're risking 4th degree burns. you can do what you will, but I don't think it's a good idea to encourage others to neglect basic safety precautions.
Apr 18, 2008. 3:51 AMtom0112358 says:
Better to use no gloves than ones that are not fit for the purpose. LN2 will vaporize easily in contact with skin but if a porous surface is presented it can easily absorb into the material which subsequently acts as a more efficient heat exchanger. That said, handling dewars is no problem but filling them is a different story and appropriate measures should be taken. The greatest risks of using LN2 are burns not from the liquid itself but from objects that have been super-cooled. Also wise to avoid confined spaces as 1L LN2 ~ 1 cubic meter of displaced air.
Apr 18, 2008. 4:19 AMogorir says:
I'll agree to that. but, a pair of appropriate rubber coated cotton elbow length gloves are a drop in the bucket compared to the cost of a dewar. I was merely pointing out that it is better that the audience have a fair amount of reverence for the materials they might be working with.
Apr 17, 2008. 3:17 PMMycroft2152 says:
100,000 ft via balloon. There is a group that routinely launches many small projects to that altitude at no charge.
Check out PONGSAT at http://www.jpaerospace.com/pongsat/index.htm
Myc
Apr 9, 2008. 11:18 AMlebelt says:
Very Nice, but the question must be asked, how did you get liquid nitorgen? and why would you need to test electronics for going to space? I like your instructable.
Apr 9, 2008. 1:24 PMKiteman says:
I think he's asking - "are your electronics actually going into space?"
Apr 9, 2008. 2:26 PMKiteman says:
Oh, a weather balloon - I was hoping your were involved in some university rocket-shot.
Apr 14, 2008. 6:16 PMleebryuk says:
Weather balloons are the unsung heroes of space exploration. They do what a lot of NEO satellites can, at a pittance. They can stay aloft for weeks, can be brought down on command (no needles needed) and the instruments can be reused again.
Apr 10, 2008. 1:09 PMstatic says:
LOL You don't think the university folks aren't doing it for fun? Just don't tell anyone the truth :) Many independent groups partner up with university groups. As long there is an educational value the science depart can and do supply things perhaps even the test fixture featured here freeing up the in dependants funds for other things.
Apr 9, 2008. 3:27 PMjongscx says:
oooh... hippy rocketry? srry, conservative roots equate indie to hippy...
Apr 10, 2008. 1:41 PMstatic says:
??? Respectfully your roots must be of a hybrid stock. Conservatives have long championed private, independant initiative. Or is that only the initiatives they support? :(
Apr 11, 2008. 5:27 PMjongscx says:
Sorry, by "conservative" I meant "stick-in-the-bum"... You know the type that still believes that anything that goes against the norm is wrong, piercings and tattoos automatically mean you listen to heavy metal, have sex before you're married and you will get aids... conservative. I guess I should've said traditional or something. Getting off-topic, srry...
Apr 10, 2008. 3:00 PMstatic says:
Nice project. You made it to hackaday, few instructables do, congradulations What do you mean when you say "press" fitting for the coper pipe, is press short for compression? In the event you are speaking of the common ferrule commpression fitting used with copper tubing, I never found them diffucult to work with. I found them to be very mechanically secure, but I wouldn't use them to support weight. I have known them to with stand up to 1,000 PSI without failure.
Why such a large fan, is there a need for speed and volume when circulating the lack of heat inside a dead air space?
I have been monitoring the telemetry of payloads launch other groups for over 20 years now, is your group reviewing their experiences? I'm physically locate between the launches of the EOSS http://www.eoss.org/ and of HABITAT http://habitat.netlab.org/index.shtml
Good luck on your future flights.
Apr 11, 2008. 5:44 PMDjProToJeeX says:
yay for hackaday
Apr 9, 2008. 5:24 PMpeanutb says:
Knowing where this was made, ventilation really isint a problem in a warehouse space. I doubt someone would be building an edge-of-space payload, much less testing it in a small room.
Apr 11, 2008. 5:09 PMpeanutb says:
Ah yes. Everyones favorite butcher shop. With pantless people walking around.
Apr 11, 2008. 6:00 AMMadScott says:
I hope you're testing the materials used in the glider at the same temperatures. Getting the plastic components well below their glass transition point (Tg) may embrittle them, as will many metal components. It'd be a shame to lose the project because a control horn or mounting bolt snapped or the wing skin fractured.
Apr 10, 2008. 12:43 PMdeenko says:
If you want to test the electronics at those temperatures, why not just dunk the electronics in LN2? The issue is thermal capacity. The upper atmosphere will be almost infinity cold, so any object up there exposed should be tested 100% at those temperatures. If you are measuring -55 away from the cold tube, then you can assure that the parts are not being truly tested at -70. If you are testing insulation, etc, then the same test holds. If the object is mechanical, and can not be submerged, then try putting just above a pool of LN2. Enclose the chamber and blow the fan. Also, those plastic coolers are fun, but they tend to become too brittle with cryogens. They also conduct too much heat, as they are designed for 0C, not -70C. I would recommend those cheap Styrofoam coolers from the dime store. They are cheap, work down to 4K, and are easily cut to make forms.
1-40 of 50next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:3ricj
