Thermo Bottle
HomeReuse by
1,210
18
Posted
Introduction: Thermo Bottle
Thermo bottle used to maintain liquids temperature for longer time.
I use it to keep water cooled in my vehicle for the whole day, and it works great!
The polyurethane foam is one of the bests insulating materials in market.
Step 1: Materials Needed
1 Big plastic bottle (aprox 2,25 litres)
1 Smaller plastic bottle (aprox 1,5 litres)
1 cutter
1 polyurethane foam spray
1 pair of gloves
Step 2: Cut the Bottle Top
Cut the bottle top of the big bottle, so that the small bottle top can fit in.
Step 3: Cut the Bottle Base
Cut the big bottle base, leaving 1 to 2 centimetres to act as a cover.
Be careful! Do not cut the whole bottle base!
Step 4: Make Small Hole in the Base
Make a small hole in the bottle base with a cutter, 1 cm x 1 cm approximately.
Through this hole the excedent polyurethane foam will go out.
Step 5: Fill in With Water
Fill in with water the small bottle, trying not no leave any air inside and making enough presure to the cap.
Step 6: Verify Fit
Verify that the small bottle fits in the big bottle, so that 1 cm is left in the diameter. This 1 centimeter between bottles will be used to fill the polyurethane foam.
Step 7: Fill Top
Fill with polyurethane foam the superior part of the big bottle and then put the small bottle in.
Very important! Use gloves for this step! The polyurethane foam adheres stongly to your skin, and might be difficult to take out.
Step 8: Fill Entire Piece
After fitting the small bottle into the big bottle, fill in the laterals with polyurethane foam. Wait for a few seconds for the foam to completely expand and then execute pressure on the bottom cover. The excess will go out by the bottom hole we did in previous steps.
You can use tape to help you keep the base in its place.
Very important! Still use the gloves for this step!
Step 9: Cleaning
After three hours, proceed to clean the excess of foam, now without gloves in. Only use your hands; polyurethane does not adhere to plastic very strongly, so it will be easy to take out!
Step 10: Finished Bottle
Take out the water and fill in with desired liquid.
Enjoy your Thermo Bottle!
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    2 Comments
    Very clever! Looks like it got kinda messy there for a bit, but you cleaned it up very nicely. Cool!
    Thank you! Yes, it might seem messy at first but the result is fruitful, believe me :)
