Introduction: Thermoelectric Generator
Picture of Thermoelectric Generator
u can make ur own generator and use it in certain emergency conditions
lets have a look in how to build a Thermoelectric generator..
Step 1: Step 01
Picture of Step 01
we need
1. Peltier plates 12v
2. some metal case and stand
3. boost circuit made or bought as module some screws
4. some strong adhesive
5.voltage regulator
6. adhesive
Step 2: Step 02
Picture of Step 02
fix the metal case onto the stand where the holes are provided and make it fixed
Step 3:
Picture of
place the peltier plates in and take out the wires through the holes provided to make the plates to get stabilized in the case
find some heat insulating small tubes to prevent the contact of wires along the case.
Step 4: Step 04
Picture of Step 04
place the Peltier plates and then place the metal plates onto the plates and make it to be stabilised for some time and then ............
Step 5:
Picture of
place some adhesive in its sides to prevent the flow of or leakage of cold water going to be poured in.
Step 6: Step 06
Picture of Step 06
place the candle and the boost circuit in their respective positions as shown in the figure.
if un able to get a module make one using the components necessary and make a boost module on the bread board.
Step 7: Step 07
important notes
1. make the cold water enough chilled to make the heat produced by the candle to get heated.
2.if u make a boost module u must provide separate input voltage for the boost module.
3.use a voltage regulator for better safety.
hemaraj (author)2017-02-05
Awesome Idea But Rejected By Dumb Peoples
ironsmiter (author)2016-03-12
peltiers are a LOT less efficient than TEG modules.
the increase in efficiency is well worth it, if you are ordering parts anyhow.
if you ripped the peltier(tec) out of an old computer cooling system or picnic cooler, then definitely give that a go first. free is almost always cheaper than store bought. at least until Murphy starts talking about his law.
Steve CSJ (author)ironsmiter2016-03-17
thanks for ur words...
alby21europa (author)2016-03-12
nice
About This Instructable
1,596views
12favorites
License:
Bio: i like to know............. everything
More by Steve CSJ:The Black WIDOW CNC MachineUSB LampThermoelectric Generator
Add instructable to:
