Thin Rip Jig
5,463
155
6
Posted
Introduction: Thin Rip Jig
This thin-rip jig is used to make thin strips on the table saw accurately. It avoids the safety issue associated with ripping stock while the blade is close to the fence.
Step 1: Building Blocks
Cut two thin pieces of stock. Router the base piece to create a track for the smaller piece.
Step 2: Shape
Drill a hole in the front of the tracking piece and cut an angle around the hole Drill a second hole in the top tracking piece to create a bolt track. When drilling this hole drill through both the base piece and tracking piece so that they are in alignment. Router the bolt track from this drill point.
Step 3: Miter Slots
Cut two thin pieces of wood. The first will fit into the groove at the base of the miter slot. The second will sit on top of that piece and rise about a centimeter above the table top. Glue together.
Step 4: Groovy
Router a groove in bottom of the base piece to fit the miter slot piece. The base piece should sit flush with the table top.
Step 5: Hardware
Countersink the bottom of the base piece to hide the head of the tracking bolt.
Step 6: Oil
Finish the wood with Danish Oil.
Step 7: Glue
Glue the tracking piece to the base piece.
Step 8: Bearing
Attach a bearing to the front of the tracking piece. I used a skateboard bearing.
Step 9: Rip
Attach the tracking piece to the base and rip some strips.
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
1 Questions
What are the 4 holes at the back of the jig for?
It was a piece of scrap wood that already had holes and they serve no purpose.
3 Comments
Beautiful!
Genius idea! I really need to spend a month building table saw jigs! thanks for the post!
This is quite brilliant. I've needed something like this several times. I will be making something like this now . . Thank you!
