"Thing", Light Please!
Introduction: "Thing", Light Please!
A nice chandelier inspired Thing of the Addams family.
A hand reaches out from a mysterious box in the ceiling and holding a light bulb. I love this idea!
Now I'll try to explain how I realize it.
Step 1: Realization of the Hand
First, I am dedicated to the realization of "Thing" and I ​​used the technique of papier-mâché then I created a silhouette of my hand using wire mesh. I tried to be as accurate as possible. I overlapped many trips of paper and I collated in with plenty of vinyl glue.
When the paper was dry, the hand had to be plaster. I covered the whole hand using a brush and a spatula. At this stage I tried to correct the imperfections due to the mesh, holes, depressions, bumps, etc...
When the grout was still not completely dry, I sponged the surface with a damp sponge, this helped to level out well and you avoided having to sand with sandpaper later.
Then I colored the hand with a paint spray.
Step 2: The Box
The box has a hole in the bottom to pass electrical wires and a lath with a hook to hang the box. This has been colored with spray paint, too.
The hand has been attacked to the box using a bracket and the bracket has been locked in hand with polyurethane foam.
Step 3: The Work Is Done!
The holder has been attached to the fingers with silicone. The cover has held in place with a hook kitchen and a rubber band.
I fixed the electrical system and the work is done.
The cost of the chandelier is very low.
For Italian version visit http://www.tutorial360.it/default/tutorial.php?id=237
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    neat idea, something that my wife would love
    Cool... nice job! :)
    The original formula I found was just a standard paper Mache formula used with dryer lint instead of newspaper. It was basically 2:1 water to flour, heated. I do a lot of paper craft and paper sculpture so I have made many changes and revisions over the years. Most of the time I use one of three recipes depending on what I am doing.
    If I am just covering something with strips of newspaper, I use a basic paste.
    2 c. water
    1 c. all-purpose flour
    1/4 c. sugar
    1 tbsp salt
    1 tbsp alum
    mix well, heat until thick
    If I need to fill in a mold or create detailed sculpture I use this:
    1 c. of basic paste (see above)
    1/4 cup Elmer's glue-all
    1 c. joint compound (powdered form)
    1 tbsp oil (I just use an oil that smells good, I don't think the type would matter)
    Water + Finely shredded paper or toilet paper
    Soak the paper in water until it is a thick, gooey, glob of pulp. Strain out excess water, Mix ingredients. Slowly add the ingredients to the paper. Add water as needed until you get a thick, spreadable constancy.
    When you work with it you can shape it very nicely, but I have found that if I keep trying to smooth it too much it just pulls apart. I usually let it dry, then sand it to smooth and use a final coat of the next recipe.
    When I want to finish off a paper Mache sculpture I create a sort of "slurry" mix using the following:
    Previous recipe before adding paper
    dryer lint, extra glue-all and water
    create the same as previous except use dryer lint, then add glue-all and water to thin the mixture as needed fill in gaps and smooth out the finish.
    If an even smother finish is required, use pure joint compound as a slurry but work quickly since it hardens quickly.
    I have been trying to work out a new recipe using reconstituted paper mache but I have not perfected it yet. I want to get something with the constancy of paper mache that has joint compound in it, but with a much longer working time and a less grainy texture.
    Thank you for your detailed answer.
    I'll try the formula to create something for Christmas.
    It would be more interesting to rig it so that when you turn the light on, the hand comes out of the box and returns when you turn it off!
    It would be fairly easy to modify. Just install a small servo motor, relay, a couple of stop switches. The relay would have to be wired so that when the power drops below a certain voltage, it triggers the servo motor to switch directions. The stop switches keep the motor from extending/retracting too far.
    something like useless machine ... useful!
    my thoughts exactly for version 2!
