3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Things to do with a old computer
Step 6Motherboard, CPU and RAM
OK since there isn't many uses for these parts I shoved them all into one step.
Processor-
OK to be honest you can't do alot with a processor but surprisingly you can make a hairbrush and a belt buckle.
1.Gold Plated Hair Brush
This ones pretty self explanatory, get a processor and glue it to a chunk of wood or metal; But heres the link anyway
See HERE (If your not bald)
2.A Geeky Belt Buckle
This ones quite cool but I wouldn't wear it as a everyday belt.
See HERE
_
RAM-
At first I didn't think there was much usage for RAM except put them all into one computer and put it to use as in the 1st step, but stranoster brought these to my attention.
1.RAM comb
To go with your processor hairbrush!
See HERE
2.Make it into a mood light
Surprisingly its possiable.
See HERE
Motherboard-
You may be asking me " What possibly can I do with a old motherboard, well the answer is not very much.
1.Make it into a bracelet
I don't really recommend this as the motherboard is full of poisious chemicals but Meh here is the link.
See HERE
2.Make little men/bugs!
This is very cool
See HERE
7 comments
Feb 26, 2009. 2:24 PMiMake says:
A friend of mine made a key chain out of some old ram chips. anyone know what parts of the pc should not be rubbed on skin? cut? digested? I think ram is fairly safe? Thanks for this compilation! Its great to reuse these old products! Recycling is grand! ****
Dec 24, 2010. 5:51 PMjomac_uk says:
On older electronics, the solder, as it contains LEAD
Dec 21, 2010. 9:35 AMmetrogdor22 says:
Generally I wouldn't eat anything out of a computer. But as far as skin contact, I think most of it is safe. Though I wouldn't go poking around in the Power Supply, because they have big capacitors that can carry power for a little while.
Dec 24, 2010. 5:56 PMjomac_uk says:
i wouldnt eat anything out of anything electronic full stop!...without going into a heavy chemistry lesson, apart from the LEAD content of PCB's, the next dangerous things are the electrolytic capacitors, dont open one of those and suck on it...!!!
As for the rest, unless you put the bits into a blender and make a PC milkshake, i think you are pretty safe.
Give the power supply 10-15 mins..and its safe!
Feb 27, 2011. 8:40 AMpfred2 says:
You might consider it if you read this:
http://en.wikipedia.org/wiki/A_Canticle_for_Leibowitz
Nov 7, 2010. 8:22 AMtomm0505 says:
I know that there is arsenic in some part of a computer.
Feb 27, 2011. 8:47 AMpfred2 says:
LEDs are Gallium Arsenide which is a crystal of arsenic or something. But it seems pretty harmless to me.
May 29, 2009. 10:58 PMcm0002 says:
depends on when the motherboard was produced if its post 2006 it contains NO poisonous chemicals because of EPA (or was it 2005) if its before i would be careful
Dec 24, 2010. 6:01 PMjomac_uk says:
But electronics and boards don have printed on them something like..TADAAAA!!!
I was born in 2006?
You will still find stuff in shops now from the far east that uses solder that isnt lead free, and in no way compliant with current regulations in any way!
Jun 2, 2009. 6:32 PMhondagofast says:
So I shouldn't eat the motherboard out of a C64?
Apr 2, 2012. 7:21 PMcreat0r says:
srsly, why the h*** would u? Lol.
Jun 8, 2009. 12:58 AMmage says:
i hear those motherboards tastet like popcorn shrimp :D
Jul 25, 2009. 12:49 PMdla888 says:
Drillpresses are appropriate for that task. (small ones)
Jun 20, 2009. 9:40 PMmemyselfand1 says:
Those men are awesome! I want to try that
Feb 24, 2009. 5:52 AMicebird says:
I used a bench grinder to grind the pins smooth on an old CPU and tried to drill a hole in one corner to turn it into a key-chain accessory. Unfortunately, the ceramic CPU didn't respond well to my drill bits.
Feb 26, 2009. 9:30 AMDevildad says:
You need Liquid cooling to drill a hole at a reasonable speed in a ceramic medium like that. Heat from friction is what borked your CPU.
Feb 26, 2009. 9:23 AMhailster says:
Try using some type of lubricant that is used to drill into glass. Also make sure the drill bit is going at a fairly slow speed. As you are drilling the CPU slowly add some lubricant. This should help prevent it from cracking, if you try this again in the future.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
41
Author:prodlad
