loading
Step 5: Pre-filter Your Shop Vac
'Bodies' make good pre-filters for shop vacs.  They keep the big stuff from blocking the filter pores.  This is especially handy when using a wet vac for dusty situations.
I put a quart of water in the bottom of the tank before I begin. The body is on the filter.  When I'm done cleaning, I peel the body off the filter.  ( It's turning inside out in the process. ) The big stuff is inside the body  'sack' now.  I hang/stretch the 'sac' across the top of an old plastic pitcher so the big stuff is cupped in the body.  Then  I can pour the cruddy water from the tank through the body... catching the medium and small stuff.  The  muddy water  in the bottom of the pitcher is then free enough of debris to go down the drain. The drained  'body'  (full of crud) goes into the garbage.
Great ideas. I hate throwing out old pantyhose or socks which are almost wearable. I knew there was something better for them than the landfill!
<p>Thank you, mary.parry. The landfill issue is becoming larger for all of us. I hadn't thought about the positive spin possibilities of recycling as a means of delaying or avoiding landfill... We're not just saving money and resources for ourselves, we're helping the environment that we all share. Same action - different slant. Thanks for mentioning it.</p>
<p>So many more uses for those old tights and socks; thank you! </p><p> I have made decorative butterflies out of coloured tights' legs over a wire frame, stored onions and garlic in old tights and used towelling socks as mitts to dust the shelves and ledges with, as well made sock toys from various socks. One could also slip a loop of old tights leg over a book to keep it closed while travelling or as a bookmark inside it.</p>
<p>Thanks again, fluffy owl! And thanks for sharing your ideas. I totally forgot the toy aspect, and you're the first to mention it. What are your favorite sock toys to make?</p>
<p>Knee hi stockings and pantyhose are also great for protecting young tomatoes/cucumbers/ on the vine. Keeps (most) critters out and the air/sun in for ripening. Squirrels/raccoons LOVE my veggies but they won't work too hard to get to them....</p>
<p>Thanks for sharing that! (There are six raccoons in the tree behind us.) Never thought of repelling them your way. I haven't tried covering veggies, but had spiderless grape bunches the year I covered them when they were green, tiny and hard. Some people use them to cover apples to discourage apple maggots and codling moths. I tried it with quince, but all the covered ones died. Maybe I broke the stems when putting the pantyhose on. Hope you're having a great harvest!</p>
<p>Great ible !</p><p>You must have used a collection of several years of old hose for this .</p>
True! Thanks!
two we always used pantyhose/stockings for were onion storage and lint traps. We had a garden and grew onions as one of the crops. We would put the onions in with knots in between, so we could essentially cut the bottom one off each time we needed an onion. Kept them so they could breath and not get moldy, while keeping the skins from falling everywhere. for the lint trap take the foot portion and attach to the drain hose on the washing machine. We usually used hose clamps to hold them on, so a simple screwdriver to loosen or attach.
Thanks , lowky, for sharing your uses! I really like the onion legs... air circulation would be perfect with no contact between them. I'm going to try a hose clamp to replace the twist tie I've been using. Much better! Again, I pass on what my plumber said... have a drain strainer that the lint trap can't get past in case it ever gets loose.
now this is just inspired!
Thanks, nastypuppy! You might want to cut the boot covers longer, so the whole thing wouldn't go in if a mouse jumped on it. [Hadn't even thought about mice before. If there had been pantyhose back then, my mom could have used a 'body' on the toaster... ummm don't think too hard about that]
wow! great idea. u are NOT phobic for sure. i put my foot inside a big rainboot after it had been stored (inside my closet) &amp; felt something lumpy. so i turned it upside down &amp; there was a dead mouse inside. guess he jumped in &amp; no way out. YUCK! i always save my old pantyhose anyway. after the mouse incident, i put my boots inside trash bags, etc. but this is a way better idea. u can still see the boot. thanks a bunch.
a lot of the others are obvious but this i had not thought of, i will be using this
Thanks for your comment, vanwazltoff, I'm glad you found it useful.
What clever ideas! Thanks for sharing your hard work!
Thanks! Glad you like them.
I have nylons used for tying things up, but putting the body around a large box or using over skeins of yarn to keep from unravelling is genius. I also love the idea of using them in place of plastic bags so things can breath, and using them to keep straws with spray cans instead of rubber bands that eventually rot &amp; fall off. <br>Thanks for sharing all of your ideas, they're great. <br>We use an old knee-hi to filter the rinse water from the washer. They are also great for: <br>-buffing old pillar or taper candles that have gotten dull or scratched. <br>-putting over the end of the vaccuum hose to suck up small items (change, jewelry, etc.) from a place you cannot reach without sucking them *into* the vaccum. <br>-stretching over a wire hanger that has been made into a loop to make a minnow net. <br>
Thanks, inkerbel! I'm glad there were some new uses for you. Like you, I filter the washer rinse water to keep the drain from getting full of lint. The guy who installed my washer said NOT to do it because if a knee high (or section of leg) ever gets loose, it can go right down the drain = major plumbing bills. So now I always keep a wire mesh strainer in that drain to catch any escapees. <br><br> The candle buffing idea is a new to me... mine are all dull, so I'll give it a try. <br><br>I don't have any fish to catch, but I wonder how your minnow net made with sheer nylons would work to round up small flying insects. Going to have to wait for fruit fly season.
Oh wow, that yarn idea is great! I sometimes get the skeins with patterns on the inside of the labels, but when you take the label off, sometimes the skein is more likely to unravel. What a great idea for keeping it together! :)
Thanks, deltasierra! I didn't even think to try it with new skeins.
Another fantastic use: buffing shoes. I've seen a few people do a finishing buff on their leather boots for a really nice shine.
Using them to buff or rub something is a totally new facet for me. I'm looking forward to trying it. Thanks!
Hose are especially good for this. :-)
Cool ideas. A very nice instructible.
Thanks! That means a lot. I'm awed by what you do.
A good collection of uses! It's nice to see someone else sorts their myriad of pencil crayons into color groups. I might want to rethink my pencil storage after seeing your solution.<br><br>I use a toe piece as a pre-filter over the intake of the pump on my wet saw. When cutting tiles the residue is very fine and clogs the pump quickly. I routinely rinse out the stocking piece and I don't have to replace the pump as often.
Thanks, paintchick! <br><br>The pencils were a recent solution. It takes too long to find the right pencil in the whole bunch, and I KNOW I'm not meticulous enough to put each one back after each use into it's very own slot in a pencil roll. ( Brrrr! Just thinking about it makes me twitchy. ) This seems to be a workable compromise... portable, easy to put away, and if one wants to work with the pencils upright, the partially open trays can lean against something without the pencils falling out. <br><br>Would you post a picture of your pre-filter arrangement? I think many of us would be interested in seeing how you set it up. Your use of pantyhose makes even buying them new a bargain!
I use aquarium pumps with suction cup feet and the power cord and hose outlet coming out the top of the pump. It is simple to cut the toe of the stocking off 4-5 inches long into a bag shape. I then put the pump into the bag and use a plastic twist tie to secure it around the hose and power cord. I realize this prevents the suction feet from attaching to the base of the water tray but with so much gunk that accumulates from sawing tile the pump starts to slide around anyway. The pump fits neatly under the bracket for the sliding tile tray and stays in place that way. I hope this solution works for others.
Thanks! That's much simpler than what I was trying to picture, and would give more filtering surface area than just covering an intake. Smart!
My family puts a bar of soap in the toe and hangs it over the faucet of the utility sink (in the laundry room or garage). The soap will lather up through the nylon and when it starts to get small, you can just add another bar on top. You never lose it down the big drain hole. We've even used this while camping when running water comes from a gallon jug, not a faucet.
Wow! That's even easier than making lace envelopes for the ends of soap! So do you tie the soap in, or is it always connected to the wall?
To use your parlance: we take one leg, put a bar of soap inside it all the way down to the toe, tie the top of the leg to the faucet. <br>This could be done with the knee high variety of nylons too.
Love this instructible!!! <br> <br>Another use that I have found for used hose is for my fish tank. I have an external filter, and use the feet of old hose (or sections of the legs) to fill with activated charcoal in the filter. I save a decent amount of money by not purchasing the 'pre-made' filter cartridges and making my own. <br> <br>with the charcoal/hose combo you will need to make sure and rinse the home made filters under running water for a bit before using in your tank to avoid the black cloud of charcoal dust getting into the tank. <br> <br>Nano
Great idea! I'd love to see it - could you add a picture?
About This Instructable
91,357views
85favorites
License:
More by mole1:Music for Dyslexics Micro Weights - An easy alternative  DIY Bows for Embroidery Floss
Add instructable to:
