3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
ThinkSafe: A Magnetic Power Connector for Thinkpads
Step 3Epoxy the Plug
Epoxy the Plug
Now that you've got the plug all washered up, it's time to bring on the magnets. Roughen the magnets and washers with sandpaper to ensure a good bond, then mix up a batch of the strongest epoxy you're comfortable with (I'm personally uncomfortable with five-minute epoxies because they set up too fast, and I like to use an epoxy that I can cut off in case I mess up).
Make sure that your magnets firmly contact both the washer and the copper foil. The magnets will be your new ground contact, so make sure that they have a good electrical connection to the ground cylinder on the original plug!
Use aluminum foil and rubber bands to make a seal so that the epoxy doesn't run off the edges. Prop the plug upright, and carefully insert epoxy in the spaces between the magnets. You don't want to get any epoxy on the top faces of the magnets, and you don't want to get any in the hole in the center. But you do want to fill the spaces between the magnets with a little pool of epoxy, bringing it almost flush with their tops.
This will seem obvious in hindsight: don't use an iron implement like a nail to apply the epoxy.
2 comments
May 30, 2009. 10:41 AMAvatar1 says:
You never mentioned this but somehow I think it would be important to arrange the magnets in a proper north south series but I am not sure what it would be
Jan 11, 2008. 3:13 PMtresho says:
There is more than one form of 2-part epoxy. WalMart & other home supply centers also sell an epoxy putty with a very firm consistency like that of modeling clay. It's sold in rolls about the size of a small tube of toothpaste. After you mix it by hand (wear plastic gloves), you can shove the material into & around the magnets and then let it set. No mold is required, the material is not runny. It sets up to a hard white plastic material, easy to machine with a Dremel tool or cut with a sharp knife.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:breath
