3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
ThinkSafe: A Magnetic Power Connector for Thinkpads
Step 4Solder the Socket Electrode
We're going to make the ground electrode be a washer on the outside of the Thinkpad, but the existing ground contact is way down in the socket. We're going to stick an electrode down in there. Again, we're using a strip of copper flashing, and we're going to solder it to a washer. The first picture is the finished product.
The strip should be slightly narrower than the ground contact inside the Thinkpad power socket, otherwise it won't have such a good connection. Do some test fittings on the laptop and bend a right angle into the strip so you know where to solder it. The strip should go all the way to the bottom of the socket. You can see that I folded over the end so that it fits more tightly.
Then, fire up your soldering iron and solder the strip to the washer. I found that the best soldering strategy is to heat the washer with the iron on one side of the strip (use a small blob of solder to increase heat conductivity), and have fresh solder ready to flow under the strip on the other side.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:breath
