ThinkSafe: A Magnetic Power Connector for Thinkpads
My Thinkpad's power connection started getting flaky, so I made a magnetic connector that works just like Apple's MagSafe connectors. It's effective, cool-looking, and breaks away cleanly when kicked. I used common materials that I had around or could find at my local hardware store, so you should be able to duplicate my efforts.
These directions should work for any power connector that has the same basic design, if you make adaptations for differing sizes. See the second and third pictures in this step for a "before" portrait and a little bit of terminology.
This modification isn't destructive in any way, so it should be possible to restore your laptop to its original condition just by removing the pieces you've glued on. You can't use an unmodified power adapter once you've modded your laptop, but fortunately it's pretty easy to make the plug part, so you can make two or more spares.
Remove the battery before working on your laptop, and unplug the power cord.
Step 1Materials
Materials
In addition to what you see here, you need:
a soldering iron
epoxy
scotch tape
You will notice in most of the following instructions that I only used two magnets. This is because during my initial build, I thought that two would be sufficient, and it was only when the whole thing was built and photographed that I discovered that they were not. Rather than start over, I simply used my Dremel to insert another two magnets, and the final design you see on the first page was born.
Depending on how many materials you already have, this should cost less than $30 for the whole project.
87 comments
1-40 of 87next »
Feb 13, 2007. 7:27 PMFireSnake says:
Great idea. i like it a great deal, but what about the magnets affective the hard-drive and other components in the laptop? Other than that, this idea can be used for other things as well...thanks
Feb 18, 2010. 3:38 AMlukeyj15 says:
 You can't wreck a hard drive with magnets
They actually contain 2 very strong magnets themselves
Jul 10, 2010. 7:31 AMgreggspen says:
i have seen someone total their hard drive by sticking neodyium magnets on the keyboard. they are magnetic storage devices after all. So any strong magnetic field applied in an uncontrolled manner will corrupt the information on the disk. however the magsafe link is a long way from the hard drive.
Jan 6, 2011. 2:12 AMbeehard44 says:
their case is shielding the inside from external magnetic forces
i tried it
Feb 15, 2010. 11:18 PMheavystarch says:
Those are neodymium magnets.  Very powerful magnetic field but has a very short reach so to speak.  Once you get 5-10mm away their magnetic flux/field is at it's end.  So your hard drive is safe.
Nov 5, 2007. 12:28 AMbigjeff5 says:
You'd have to pull the hard drive out and set the magnets on top of it to do any damage, mod away without fear! Magnets outside the computer are rarely a problem, unless they are very powerful and they happen to touch just the right spot.
Jun 6, 2009. 12:34 AMuberdum05 says:
Well, if they can manufacture HDD's with the super-duper strong magnets next to the platters, you'd probably have to put them directly on top of the platters.
Nov 27, 2011. 9:13 PMjbates10 says:
do you know how HDDs work? the magnets are electromagnets and write data onto the disk. they turn on to mgnetize a spot on the disc to store a bit. if they want to demagnetize the bit, they use the other electromagnet with reverse polarity. making a spot of 1s or 0s on your disc would be bad
Mar 7, 2010. 9:38 AMDude567 says:
 "Be wary of stainless steel or brass washers; they're not magnetic." Since when was stainless steel not magnetic? It is made of nickel and steel and both are magnetic. Unless your stainless steel is called chrome then it's magnetic.
Aug 18, 2010. 8:28 AMkoko3052 says:
Do some research Dude. Stainless steel is NOT magnetic!
May 5, 2010. 7:00 PMdominicfortune00 says:
Whether stainless is magnetic depends on how much chromium is included in the mix.
The more expensive grades of stainless are non magnetic due to a higher chromium content than the magnetic grades of stainless contain.
Jun 20, 2010. 8:18 AMMelty Mcface says:
This looks good. My sister's HP PSU recently gave up the ghost so I'm looking a way at reducing the mortality rate of the upcoming replacement. I was thinking of a mag-safe breakaway cable that required no modding. I'd have to obtain a 4.7/1.7mm plug (I think we sell them where I work) and a line socket (a little harder) make up a short cable with a line socket on on end, and a mag-safe type thing on the other, to which you'd plug in the existing PSU, then with the plug, you'd add the other side of the mag-safe, and leave that sat in the laptop's socket. Two parts, easily removeable, no modding. If I ever get around to this, I'll most certainly reference you. Where's a good place for magnets? (preferably international shipping)
Feb 16, 2010. 11:08 AMaliyevzaur1989 says:
you can destroy your hard drive with that magnets if close enough.be careful
Feb 16, 2010. 2:00 PMmikeread says:
ummm  you cant really
Feb 26, 2010. 10:49 AMaliyevzaur1989 says:
take a try.you`ll belive me
Feb 15, 2010. 5:17 PMeyebot117 says:
Clever! I would personally add the magnets to the computer instead of the cable. Then there wouldn't be any way for the magnets to harm my hard drive should the cable come near it. Despite the fact that the magnets probably won't affect the computer, stronger magnets and sensitive expensive electronics usually don't mix well.... Good coupling!
Dec 1, 2006. 11:15 AMschaadrak says:
Another way of doing this would be to cut the cord about three inches from the connector, then connect the wires on the cut ends of the cord to the magnets so that the magnetic leads are only attracted to their proper mates. You know, so that ground attracts to ground but repels V+. That way your not gluing stuff to your laptop and the magnets are further away from the hard drive. Not that this isn't a fantastic mod, though.
Dec 25, 2006. 7:29 PMhack124x768 says:
I think the magnetic break-away cable idea is a good one. It would be much easier to make. If you were really worried about reverse polarity, you could just throw in a diode bridge or rectifier on the laptop end of the cable.
Feb 14, 2010. 12:18 PMKegtapper says:
A diode bridge only used for AC to DC.  The power is already DC coming from the adapter.
Feb 15, 2010. 12:59 PMshetonus says:
Think about it a little further Kegtapper, AC is composed of alternating polarities, and a diode bridge outputs a single specific polarity.  If your bridge is hooked up to provide the output you need, it doesn't matter which polarity you apply to the input.
New inventions are often created from old things used in new ways. An inventor might say that something is usually used for a specific purpose, but shouldn't ever say that anything is used for one purpose and for one purpose only.  The Chinese used to think that gunpowder was only for fireworks.
Feb 14, 2010. 3:52 PMYerboogieman says:
I want an older Thinkpad so bad, but for the same price I can get a new laptop without the "nipple".
Feb 14, 2010. 3:32 PMcodongolev says:
our deep fryer has one of these on the power cables. because it isn't really a good thing when a pot of hot oil goes all over the floor.
Feb 14, 2010. 2:13 PMstatic says:
 Great instructable too bad it isn't  very easily applicable to my mini9 power connector. Looking forward to reading your ring magnet version.
Nov 17, 2006. 11:45 PMandrestuff says:
I had wanted to make a connector that when I plugged it in as I drove up to my car it would put 110 vac into the car. Then in the morning I could have a regular electric heater come on for 20 minutes or so and really warm up the inside of the car. Then rather than slipping around trying to unplug it in the cold I wanted a way that I could just "drive off" . And the unit would unplug itself. Obviously a regular power cord WOULD work but it's not very proper way to do it. This idea is pretty good if I could have made up a couple of sockets with protected 110vac holes that pins would drop into. Thanks for the help with an idea. It might still work for me.
Feb 14, 2010. 1:48 PMstatic says:
Shop around for used kitchen appliances that use magnet to retain the power cord to srip the parts off. You would still have to hook it up, but could drive off in the morning.  I believe Anderson Power Poles have products that will make  a mechanical electrical connection, but you'll pay for those. Anyway tou could make  standard cord connection work, if you devise a way to have someting other than the electrical cord to take the strain of pulling the connector apart.
Oct 5, 2008. 12:01 AMdchall8 says:
I wish I'd seen this about $300 ago. My daughter can't seem to keep from knocking the plug out of the inside of her laptop. I can't believe it never occurred to me to look here for an answer. I never did get the magnetic plug thing until my wife brought home a Macbook from her school. Now I'm convinced. Leave it to Apple to innovate for the rest of us. This is a fantastic Instructable. Could you just clarify how many magnets to use ;-) -seriously though, the ring magnet is the way to fly. Great job!
Feb 14, 2010. 1:29 PMstatic says:
As it often soes Apple copied another idea that has been in existance, not that I'm saying apple hsn't had any original ideas. My inexpensive Dollar Store deep frier uses magnets retain the power cord.
May 30, 2009. 3:02 PMthefunktopus says:
it says 4 if you scroll over the magnest in the second picture
Oct 26, 2006. 4:46 PMzachninme says:
I am actually working on a USB version, not to be "breakaway", but to be unisex, so that a male = female connector. Coming along well-ish.
Oct 28, 2006. 7:02 AMMyself says:
You should look at the construction of the Anderson "powerpole" connectors, and the old IBM Token Ring genderless connectors, for design ideas. Also the old General Radio coax connector, and the APC-7 instrumentation connector. Just curious, what do you intend to do with a genderless USB connector, aside from accidentally connecting two hosts together and watching their power logic fight and/or fry? Is On-the-Go common enough to justify this?
Oct 28, 2006. 1:46 PMzachninme says:
I have just so many different USB cables hanging around, and I can never match A to B... so to speak. I am smart enough to not do stupid things... Oh, and after reading my post, I forgot to say why I posted it here. I was planning on using magnets, and this instructable was inspirational.
Dec 16, 2006. 12:27 PMzachninme says:
And actually, I just figured it out awhile ago, sorta. Not exactly what I had in mind, but awesome none-the less :-) Instructable coming soon!
Feb 14, 2010. 12:14 PMKegtapper says:
Has anyone consider the low current rating of the USB connectors? If I remember correctly the Acers use 19v @ 3.4A  And USB connectors are rated considerably lower. Most of the USB devices don't even carry 1A.
Watch your power rating, or you will have a melted plug stuck to the side, or worse yet, a short that cannot be pulled out.  Yes I am a 'Laptop Doctor'
Aug 25, 2008. 4:08 PMtinyrose says:
I want to make the same thing, magnetic USB connector. Where can I read the instructions? Can you solder any wire to the surface of the NIB magnets? Do you have to wrap the magnets with some kind of copper or tin strips? Thanks for sharing.
Sep 2, 2008. 9:06 AMPKM says:
You can probably solder any common type of wire to the magnets, with a few gotchas to watch out for. Firstly, aluminium is not great for soldering to because it is covered with a layer of very hard oxide which stops the solder "wetting" it properly- you have to sand aluminium quite hard if you want to solder to it. Copper tends not to have this problem, iron/steel might and stainless steel will probably also need sanding. Secondly, soldering to magnets is not a great idea because magnets don't like heat. Excessive heat makes magnets lose some or all of their magnetism (depending how hot you get them for how long), so soldering to magnets is usually discouraged. You are probably better off letting them stick themselves to a piece of steel, adding epoxy around the sides to keep them in place, and then soldering the steel connection to your wires to keep the heat away from the magnets. This instructable uses epoxy and contact fittings to avoid soldering near the magnets at all, and that is probably the best solution if you can do it.
Jun 25, 2007. 2:01 PMNormMonkey says:
This is great! I wonder if anybody has tried it with poured resin instead of epoxy, maybe enclosing the group of washers as well so that only the magnet surfaces are exposed? You could pour too much and dremel / sand down to expose the magnets after. Stick a bit of tightly rolled paper topped with clay in the tube part to keep resin out of there.
Jan 20, 2010. 7:50 AMcptomes says:
Epoxy is a type of resin.  Most epoxy resins are liquid and can be poured.  5min epoxy is the exception, not the norm.  You might be thinking of polyester or vinylester resins.  I am building a Cozy MKIV which is epoxy/fiberglass/foam composite.  Most epoxy you see in hardware stores is the 5min variety, mostly because it's pretty expensive compared to polyester resin, and most varieties of epoxy use pretty nasty chemicals for the hardener.  Brain damage, skin reactions, etc.  As always follow the safety instructions on the packaging!
Jun 25, 2007. 2:09 PMNormMonkey says:
Last but not least: the power plug from the adapter had that recessed post-receptacle for a reason: they don't want to shock users with 16VDC. This mod bypasses that safety factor. The MagSafe has 16.5VDC on its pins too but the middle one keeps the plug from being energized unless it's connected to the laptop. This one will be energized full-time. I'd guess 16VDC isn't enough to hurt if accidentally touched with fingers, but if you have kids I'd think twice about this. I don't have kids so it's a-modding I will go! Thanks for a great idea! I can see this being useful for all kinds of power sockets, too. Another idea: they make ring-shaped rare-earth magnets *grin*
Jan 20, 2010. 7:45 AMcptomes says:
Most smart power supplies automatically shut off when shorted.  I wouldn't put this kind of connector on a "dumb" wall wort type of PS.  But a laptop PS has a lot more going on than just a DC source, even the ones with just ground and power connections.
1-40 of 87next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:breath
