loading
I was struggling with ideas for my next project, then it dawned on me.  I needed a Thinking Hat!
Looking around in my shop, I found I already had all the necessary materials to construct such a time-honored headpiece.  The materials used were:
- an old hard hat
- an old power tube from a previous project (https://www.instructables.com/id/Rescue-a-vintage-TV-cabinet/)
- a toggle switch
- an "AAA" battery holder (and batteries)
- a "mystery" red LED (I call it a "mystery," because it came unmarked in a box of junk parts I bought once upon a time)
- wire
- an empty wire spool
- an old coiled cord
- a little round "thingy" from an lamp
- a couple of feet or so of brass rod
- solder
- heat shrink tubing
- and my old standby....hot glue
The tools used were pretty simple: a drill, drill bits, and soldering gun
Step 1: Preparing the Hard Hat
The hard hat stood before me like a pure white canvas (photo 1), ready to be magically transformed into a Hat Of Deep Thinking.
My plan was to mount a huge old vacuum tube on the top (sort of like an "idea" light bulb), stuff a red LED up through the base so it would shine through the glass, and wire it all together with batteries and a switch.
Looking around, I realized that the pins of the tube would fit nicely inside of an old plastic wire spool, so I bolted the wire spool to the top of the hat (photo 2).
Step 2: Preparing the Vacuum Tube
The vacuum tube I used was from the power supply of an ancient television (photo 1).  I began by soldering wires to the leads of the LED, then carefully drilling a hole through the bakelite base and stuffing the red LED all the way up to the base of the glass part of the tube (photo 2).  I had marked the wire for the positive side of the LED before stuffing it inside the tube's base so I wouldn't have to experiment when it came time to wire up the circuit.
Since this was a "mystery" LED, I had no idea what it was rated for, so I began testing by applying 3 volts, and then testing a variety of resistors in the circuit.  I wound up staying with 3 volts and using no resistor.  I suspect this is probably a 5v LED, but 3 volts with no resistor seemed to work fine.
Step 3: Installing the Vacuum Tube
I hot glued the vacuum tube to the empty wire spool I had previously bolted to the hard hat, then made a couple of wire bales that attach to the top of the tube (using some unknown lamp part from my junk drawer), and attaching to the hard hat through holes I drilled.  I reinforced all these attachments with hot glue.
I then attached a coiled cord on the left and right sides (through holes I drilled), and hot glued the center to the unknown lamp part I had placed on the top of the tube.
Step 4: The Electrical Stuff....
The electrical stuff was very simple.  I bolted an "AAA" battery holder inside the hard hat, drilled a hole in the front for a small toggle switch, then hooked it up to the LED wires coming from the vacuum tube.
Step 5: The End Result
I have been noticing that simply wearing the Thinking Hat can make a big difference, but when I want to do some really deep thinking, all I have to do is flip the little toggle switch on the front of the helmet and, WHAM, the thinking really gets DEEP quickly!
If you've ever thought, "Gee, I wish I had a Thinking Hat," I hope this little Instructable will inspire you to make one.  Have fun!
<p>You should try the pro version 20.00006 it has a multitude of vacuum tubes and empty spools of plumbers tape. </p>
<p>or empty solder spools</p>
Cool, and Is the book your reading upside down?
Yes, it is indeed upside down. It's because of the Thinking Cap, you know.....
Yeah, I figured that out.
I really like the hat, but I REALLY like the photo.
You could adapt a TDCS kit to overclock your brain and make it a real thinking hat! ;)
This made me lol and kinda reminded me of portal for some reason. Now you're thinking with hardhats.
The unknown lamp part is called a harp.<br>
Here is a Demotivation from me to you :) <br><br>http://www.demotivation.us/thinking-cap-1250959.html<br><br>I love this instructable, by the way.
Ha! Thanks for the comment, and thanks for the link to the demotivation!!
This is very well thought.<br>As a matter of fact as it was conceived BEFORE you built this cap I think that you don't actually need it and you should give it to someone who's thinking abilities want such a boost : be kind to your neighbor ! &hellip;
Well............... Actually, I didn't think about building it until I taped the vacuum tube to my head and felt its energy filling the great void that exists between my two ears. Then a voice spoke to me saying, &quot;Must get old hard hat, empty wire spool, LED, and lamp part 'thingy' and assemble into a Thinking Hat!&quot; I've often wondered if the voices only speak to me....... Enjoyed your comment!
Aaaah ! That explains&hellip;<br>So make a good use of it. You already did by showing how useful it is.<br>Guess I'll end up making my own ; French style of course, I don't want my fellow countrymen see my think with an accent (but then again !!&hellip;&agrave;.<br>Enjoy your week end as much as I enjoyed your instructable ! &hellip;
coooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo.......... <br>3 years later <br>.....oooooooooooooooooooooooolllll
Thaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaanks!!!!
lol
Silly and wonderful :D
Wonderful, yes, but silly?!?! I mean we're talking about a real, carefully designed and tested Thinking Hat. When it come to thinking, I need all the help I can get! Thanks for your comment!
Brilliant - add a cooling fan and trolls the world over will flock to your door.
The line of trolls at my door is already so long, they're complaining about the long wait time! Thanks for your comment!
Why not make the heater glow? That would have been this much more awesome.
I would have liked to make the actual heater glow, but alas this old tube's heater would not cooperate. Thanks.
Splendid, <a href="https://www.instructables.com/id/Brain-phffArt-Kinetic-Trophy/">great minds think alike</a>.
Thank you! Also, thanks for the &quot;great minds think alike&quot; link -- I enjoyed it.
About This Instructable
5,616views
12favorites
License:
Bio: I enjoy taking a pile of junk and making something unusual out of it. I like wheeled vehicles, and currently own two motorcycles, two electric ... More »
More by knife141:Chromebox Computer In Old Case Easy mp3 amplifier Gas Nozzle Lamp
Add instructable to:
