Thirsty Flamingo
27,619
94
22
Posted
Introduction: Thirsty Flamingo
The Thirsty Flamingo will help you monitor the moisture levels in you plants.
This project was built using our online schematics and code generator circuito.io
Step 1: Planning the Circuit
Generate the up-to-date schematic & code for the Thirsty Flamingo project using Circuito.io (all relevant parts are predefined).
The electronic components we used for this project:
Input: SparkFun Soil Moisture Sensor
Output: Piezo Speaker - PC Mount 12mm 2.048kHz
Additionals (to output):
Transistor - NPN BC337 Diode
Rectifier - 1A 50V
Resistor 1k Ohm 1/6 Watt PTH
Controller: Arduino Pro Mini 328 - 5V/16MHz
Power Supply: 9V Alkaline Battery
Step 2: Assembling the Circuit
Using the schematics generated by our system, you can built the electric circuit.
Step 3: Upload and Customize Code
You can also make adjustments in the code if you want to change the moisture alert levels or the alert tone.
To make it tweet like a flamingo, please replace the code of the .ino file
with that:
#include "Global.h"
void setup() {
  Serial.begin(9600);
  Serial.println("start");
void loop() {
  //if the soil moisture level is low play chirps
  if (soilMoisture.read() < 600) {
  Serial.println("low");
  for (int i = 0; i < 5; i++ ) {
    //makes the sound according to: intensity, varies: normally 5. number of times: how many times tweets, rormally 3-6
    highChirp(5, 2);
    delay(100);
    lowChirp(5, 2);
    delay(100);
    tweet(2, 2);
    //delay between the closer tweets delay(400); }
    //general delay after a series of tweets
    delay(random(10000));
void highChirp(int intensity, int chirpsNumber) {
  int i; int x;
  for (int veces = 0; veces <= chirpsNumber; veces++) {
    for (i = 100; i > 0; i--) {
      for (x = 0; x < intensity; x++) {
        digitalWrite (PIEZOSPEAKER_PIN_SIG, HIGH);
        delayMicroseconds (i);
        digitalWrite (PIEZOSPEAKER_PIN_SIG, LOW);
void lowChirp(int intensity, int chirpsNumber) {
  int i; int x;
    for (i = 0; i < 200; i++) {
      delayMicroseconds(i);
      digitalWrite(PIEZOSPEAKER_PIN_SIG, LOW);
    for (i = 90; i > 80; i--) {
      for ( x = 0; x < 5; x++) {
void tweet(int intensity, int chirpsNumber) {
  int i; int x;
  //normal chirpsNumber 3, normal intensity 5
  for (int veces = 0; veces < chirpsNumber; veces++) {
    for (int i = 80; i > 0; i--) {
      for (int x = 0; x < intensity; x++) {
  delay(1000);
Step 4: 3D Printing
3D print the Thirsty Flamingo's body using the STL files.
Step 5: Assembly - Putting All the Parts Together
Place the battery and the PCB into place, connect the two body parts with screws and you're done!
Put the Flamingo in your plant dish, and it will start beeping when the moisture levels are too low.
Step 6: Have an Idea of Your Own?
If you want to create your own cool project, and need help with generating schematics or code, you are welcome to try out our system @ circuito.io
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
18 Comments
Great project !
How long long do you expect the battery life to be ?
It really depends on the battery you're using, but generally speaking, it will probably last a few weeks. You can also select a different power source on http://circuito.io :) Good luck!
Hi
Really nice project you got here, but it seems the piezo speaker functions has changed in the updated version from circuit.io. It means that the above change in the .ino-file not working. Other than that. Cool idea :)
Hi,
i did the circuit as described, but is not working correctly. When I put the sensor on the soil, it starts to sound, even when the soil is totally wet.
What may be wrong?
Thanks
Ooops!! You are so right! We have an error in our example, it should read: (A) instead of if(soilMoisture.read() > 400) use if(soilMoisture.read() < 600).
(B) also: Serial.println("High moisture detected"); should be changed to: Serial.println("Low moisture detected"); We're sorryyy! and will fix the guide accordingly. Thanks for letting us know.
Hi,
What may be wrong?
Thanks
The transistor amplifies the signal coming out of the Arduino, to get louder sounds from the speaker.
The diode is a "fly-back" diode, meant to protect the circuit from reverse currents, but in most cases this diode will not be necessary with piezo speakers, but more important with regular (coil) speakers.
And I have one more question.
Could you let me know why you chose those electronic elements but not others?
