Introduction: Make This Wooden Tool to Get Started With Fusion
Picture of Make This Wooden Tool to Get Started With Fusion
This project is a perfect example of how to make beautiful renderings even with simple projects. This is one of the simplest projects I made using Fusion 360 to help the beginners get started with the software. It shows some basic functions of the software and is too easy to take much time.
Software required:
Fusion 360 by Autodesk
Pre-requisites:
Although the Instructables is meant to be for beginners, it is recommended to have some basic knowledge of the software.
Lessons recommended:
Fusion 360 class (Lessons: 1-5 and 9)
Step 1: Make the Table Top
Picture of Make the Table Top
  • Sketch a rectangle
  • Extrude it to make the base
Step 2: Make the Table Stand
Picture of Make the Table Stand
  • Create some offset planes
  • Make some concentric circles, each on a plane
  • Use loft to make the stand
  • Join a cylinder to the base
Step 3: Add Some Fillets
Picture of Add Some Fillets
  • Add some fillets to the table top
  • Add some fillets to the base
Step 4: Get the Renderings
Picture of Get the Renderings
  • Go to Render Workspace
  • Click on Scene Settings
  • Choose "Environment" and select an environment (I've used "Plaza")
  • Check the "Reflection" option to see the reflection on the ground
Once you save the file, it will automatically start rendering. Once done, share your renderings here using the "I Made It" button!
Also if you liked this one, I would suggest taking a look at this chair too.
About This Instructable
143views
3favorites
License:
Bio: Currently, a Content Developer & Research Intern at Sanfoundry. I'm an Autodesk Student Expert. I have the Professional Traning on CFD by SimScale GmbH. I ... More »
More by alamtania:Two Storied Secret Box From a Single Piece of PaperHow I Made an Autodesk Student Ambassador Locket?Create a Set of Rainbow Pencils in 10 Mins Using Fusion 360
Add instructable to:
