Thomas Train Bed
Introduction: Thomas Train Bed
So I decided to build a Thomas Train bed for my son, who, like many boys his age, loooooves Thomas the train. Got my design inspiration from another train bed design on, hopefully a lot simpler to make.
Step 1: Sketchup
First I drew up the bed in Google Sketchup. This bed was designed for a standard twin size mattress 39" x 75".
You can download the sketchup file here. You need the Google Sketchup program (free version is enough) to open it.
Step 2: Cutlist Diagram
I used one 4x8 sheet of 3/4" plywood for the bed body, one 4x4 sheet of 3/4" plywood for the foot board/toy chest and some scrap I have for various parts. If you start from scratch, 2 sheets of 3/4" plywood should be more than enough. Alternatively, you could use 1.5 sheet of plywood and half sheet of MDF for the curves.
Step 3: Making the Engine Head
I made the engine head with 2 half circle and a 1/8" hardboard bent around them.
Step 4: Making the Rooftop
Cutting the arcs was a pain, mainly because the plywood is hard to deal with and I don't have a scroll saw to keep the cut perpendicular to the surface. In the end I had to use my router with a straight bit to cut the curves. Again, if I were to do it again, I'd use MDF.
I also used the router to cut a 1/4" groove along the inside of the arcs and the side rail so that the roof board can fit in.
Step 5: Bed Body
The bed body was straight forward to make. The two sides are identical pieces cut from one sheet of plywood (kind of like a "69" pattern). It saves wood and avoids the need to join multiple pieces together. For the decorative red sidings around the window, I used 1x4 pre-primed MDF boards.
Do not throw away the 2 cut-off pieces from the window - they are used as the 2 shoulders for the toy chest.
Step 6: Toybox
The foot board is essentially a box with opening on top and side. I didn't bother to put in a bottom for the box since I figure it's gonna be attached to the bed and sit stationary on carpet. I routed grooves on the inside of the box and turned the left side of the box into an IKEA TROFAST like storage system for toys. The rest of the toybox can still be accessed from the top for storage of bulk items, clothes, bedding, etc.
Step 7: Headboard
I made the headboard out of the left over pieces from cutting the roof arcs (the light blue pieces in the diagram). I joined them using dowel pins & glue, and now we have a headboard w/ nice curves.
Step 8: Thomas Face
For the Thomas face, I found a high resolution picture of it here. I printed it on 11x17 paper and did a decoupage using mod podge - this is the first time I try decoupage (or heard of this word). It's a good idea to have multiple prints in case you mess it up.
Step 9: Paint & Assembly
I routed all the edges with round over bits, used some spackle to smooth over the flat edges of the plywood. Painted and added couple coats of polyurethane. The assembly was straight forward too, mostly involves pockethole screws, glue and corner brackets.
Step 10: Finished
Here's the finished bed. The train engine head was fixed to the toy chest with hinges and safety lid support, giving safe access to the back of the toy chest. If you want to go nuts, cut some openings on the side of the bed and add some drawers, or better yet, train wheel shaped drawers :D
The project took me more time than I expected, about 3/4 of the time was actually spent on the design and sketchup, but it's been fun for me and the big smile on my son's face makes it all worth it.
5 People Made This Project!
  • Pocket-Sized Contest
  • Pro Tips Challenge
    Pro Tips Challenge
  • Paper Contest 2018
    Paper Contest 2018
2 Questions
Is the Sketch up file still available for the Thomas Train bed? There seems to be a broken link.
The link for the plans says it has been disabled. Could these be emailed to me?
hi your Thomas train is awesome- im looking forward to try the same, but the Plans link seems to be broken or missing, can you email me the same pls--- thanks for Sharing
Does anyone know of any places that would cut the wood for you if you do not have the tools? Thanks
its wanderfull
I like how the bed looks thx
hi guys, you all are quite amazing what you have done with these plans. I am a novice and I'm trying to do this. For someone like me who has very little experience, how did you make that arc for the rooftop? I'm trying to freehand it and it looks terrible.
Also, how are people fastening the pipe to the top of the engine head? I like the smokestack look but don't know how they fasten the pipe to the top. I am doing my best, but somethings I'm just not sure how to do. I wish the instructions were a little more detail? Like also how to fasten everything together. Thanks for help! Laura
Did you hand paint Thomas's face or did you buy decal?
Thank you for the awesome instructions! We are about to try our own version of this for our just turned two little man! Quick question about the face... Namely: how? :) Can't figure out the exact way to do it...
I printed the Thomas face on paper, then basically glued it on to the wood - try google "decoupage". Alternatively, if you are talented, try what adams070707 did - directly paint it on the wood.
For decoupage, you need a bottle of Mod Podge from HD or walmart. Put 1 coat (some suggested mix 50/50 w/ water) on the back of the wood and on the back of your Thomas printout. Glue it on and roll it flat with a roller. Let it dry a bit and add another coat over the printout to seal it in. I did mess up couple times before finally getting it right :).
Good luck.
Ah, awesome! Thank you! Will definitely try it out, and put some pics up when we're done!
