Thread Repair Motorcycle / Car / Truck / Boat Etc
1,536
16
Posted
Introduction: Thread Repair Motorcycle / Car / Truck / Boat Etc
Rosca problematica, o parafuso ja não aperta porque a rosca está moida.
Problematic Thread, the thread is damaged and the bolt is unable to tight.
Step 1:
O kit (helicoil) usado para reparar roscas de 6mm, tambem disponivel noutras medidas m4/m8/m10...
Kit (helicoil) used to repair 6mm damaged threads, also avaliable in m4/m8/m10...
Step 2:
Tirar a tampa para fora,meter os parafusos por ordem, isolar a area a ser trabalhada
Take the cover out, put your bolts by order ,protect the area that you are going to repair
Step 3:
usar a broca de 6.3mm no buraco de 6mm
Use the 6.3mm drill to drill a hole in the original 6mm thread
Step 4:
Usar a ponta que veio com o kit para refazer a rosca
Use the bit that came with the kit to rebuild the thread
Step 5:
Inserir a helicoil com o aplicador (ajustar a peça central que aparece na primeira imagem para encostar á helicoil), depois usar a peça da segunda imagem para partir a ponta que foi usada para inserir a helicoil (terceira imagem) (não tirei foto desta parte mas é facil e intuitivo)
Insert the helicoil with the aplicator (adjust the center piece to support the helicoil insertion),when its in place use the break pin tool (second image) to brake the small tip (third picture) that was used to insert the coil (i have not take any pictures of this step but its easy to do)
Step 6:
Como novo e mais forte que o original
Good as new and stronger than the original
Google translator used to help in the translation
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Trash to Treasure
      Trash to Treasure
    2 Comments
    I think I've got an M3 set, and they come in Whitworth, BSF, UNC UNF thread sizes as well but are not as easy to find.
