Step 3Fusing conductive fabric
Cut these out and then fuse them to your pieces of neoprene. Make sure that none of your button tabs come out in the same place as your common tab. In the next step we will put a piece of perforated foam between these two conductive fabric fused neoprene layers and, when nothing is pushed, none of the individual pieces of conductive fabric should be touching.
jst two faric are used in tjis project neoprene and conductive fabric plz help me as soon as possible
now its so easy to make fabric button with simple cotton any (or any other type of fabric ) aluminum foil and and fabric foam and if we use aluminum foil rather than conducting fbric then there may be a little bit problem to stitch aluminum foil or fuse
and if you mention these thing in material part then its very easy for others
