As general material I use LEDs and Soldering iron, some wires and enough time.
The three Instructable are in the physical order I made them.
Remove these ads by
Signing UpStep 11...Use your Glasses to see better...
So I get out the glasses from the framework and I added 2 leds Ultra bright White, 2 LED cases some wire, a AA battery pack, and an on/off switch. Also some wire covers to isolate the joints.
The LED case is really heavy. I choose this for better result but is a bit of trouble to maintain it at any branch of the framework, specially mine which is very thin. I use a bigger nut to support it and a tighter to give full support. With the nut I succeeded the angle i wanted of the light. I wanted each LED looks about 10 degrees more left and more right like in figure
Evilmadscientist did something similar to the urchin lamps, but with a "throwie" basis.
(You'll get more views if you upload the video to YouTube and then embed it here. You will also get YouTubers seing your video and following any link you give back here.)
