3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Three-Way and Four-Way Switches--How They Work
While a three-way switch is very simple to many who visit Instructables.com, it is a mystery to many others. Understanding how the circuit works satisfies curiosity. It can also help to diagnose a three-way switch that does not work because someone wired the circuit incorrectly.
This is the basic circuit for a three-way switch. The gray circle represents a light bulb controlled by the two switches. It is gray because it is "off." The two lines ending near the left side of the drawing go to a power source, like the circuit breaker panel in your house.
The green rectangles represent the switches. Notice that one conductor comes into each switch, but two go out. When the toggle is thrown the pathway inside the switch shifts from one of the out conductors to the other.
Here you can see that electricity can flow along the upper wire through the first switch, but its pathway is broken at the second switch and the light remains "off."
Step 1The Light Comes "On"
In this graphic someone has entered a room and flipped the switch at the right of the frame. The electricity that flows through the first switch now finds a pathway through the second switch and the light is "on" as represented by the yellow bulb.
23 comments
May 17, 2010. 2:09 PMpedalmonkey says:
 Excellent.  Whenever I wire a three-way I always have to go look it up on the box.
Jun 7, 2009. 1:44 PMReCreate says:
Ha Wow, I finally get how it works! It makes sense now!
Jun 7, 2009. 3:51 PMReCreate says:
Your welcome.:)
May 18, 2009. 10:24 PMespdp2 says:
Sweet! Thank you so much for explaining this, clear and concise. I feel like I've been "instructed." :-)
Mar 15, 2009. 7:08 PMMePerson says:
Wow, so obvious, yet I had no idea. Thanks!
Jan 21, 2009. 1:03 AMhilbert9541 says:
thank you whoever did this thing on 4 way switches. i figured a 4 way switch had 4 terminals, but i couldn't figure how it actually "switched" without leaving a completely open circuit. i think you made 4 way switches' concept very easy to understand. thanks again, josh -south carolina (united states)
Oct 14, 2008. 5:35 AMrichms says:
Thats not how they are wired here in NZ. Also if there are 2 switches it gets called a 2 way switch here since there are 2 switches. What they do is wire one of the switches normally, to add 2 way capabilities a piece of 3 conductor cable is taken from there to the other switch location, and 1 is connected to 1, 2 to 2, and C to C - the cable is red/white/blue since they are allowable phase colours (yellow used to be but in harmonisation with Aussie it was decided not to be since its easy to mistake for a green/yellow earth) Anyway, then the power is connected to the 1 terminal of one switch, and the 2 terminal takes the power out to the lamp. This is done since its normal that the power goes in and out of the same flushbox rather then taking a single conductor to the other end. It is sometimes done the way described with a wire joiner taking the cable to the C of the remote switch to the cable out to the light, but thats not how new installs are done.
Dec 11, 2008. 2:49 PMrichms says:
Yeah, thats the one (second in the top image) - sometimes it will go thru intermediate switches which just connect to the wires between the 1 and 2 terminals
Oct 14, 2008. 11:31 AMmdmoose29 says:
We call them 3-way switches because switches are already 2-way (On/Off)
Oct 13, 2008. 5:51 PMrimar2000 says:
Excellent,thanks
Oct 13, 2008. 3:49 PMSpiff73 says:
Thanks to Acme School of Stuff, I understood three-way. But, four-way completely baffled me. Thank you so much for clearing it up.
Oct 13, 2008. 10:51 AMhavanacus says:
Thank you, this always bothered me...
Oct 13, 2008. 9:57 AMScubabubba says:
Thanks Phil! I could never picture how these work in my head, this is excellent.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
476
Author:Phil B
I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying posting things I have learned and done since I got my...
more »
