Throbbing/Fading/Flashing LED with 555 Timer
This tiny circuit is a simple way to make a fading led without having to program chips or writing code. Just a few simple components and you're ready to fade all day.
The end result is a constant fade up and fade down just like a Mac on standby.
Try it! See how small you can build it.
If you like it rate my Instructable. If you don't, rate my Instructable.
Step 1Gather Tool and Components
  • last photo ←
For this project you will need:
Electrical Components
470 ohm resistor (or a resistor to drop the current for your desired led from around 8 volts.)
33k resistor ( or a 100k potentiometer for adjustable fade times)
LED ( I used Blue)
100uf Capacitor
555 Timer
Generic NPN Transistor
Copper clad board. breadboard, or project board.
Tools
Dremel or other rotary tool for drilling
1/32" drill bit for wires
Cutting wheel or tin snips if necessary to trim board down
Soldering iron
Scotchbrite pad or fine sandpaper. ( I used sandpaper because it happened to be there)
Muriatic Acid (concrete cleaner or pool chemical) Home Depot and other hardware stores have it.
Hydrogen Peroxide (standard wound cleaner) Found in drugstores, grocery stores, you probably have some at home.
Misc
Latex or Nitrile Gloves
Acetone to clean ink off of board after etch.
Outdoors area to etch in
Plastic or glass container to put etchants in.
Helping Hands clamp with magnifying glass (nice to have a third hand)
I've included the files for Express PCB software. Free download.
123 comments
1-40 of 123next »
Dec 5, 2010. 2:56 PMgameshark888 says:
nice! i built it and works fine upon powering up.. i used it to replace the led on the switch in my cpu.. looks cool! thnx!
Dec 11, 2010. 2:23 AMgameshark888 says:
here I built it and it was workin.. installed it on my cpu switch.. thnx for the instruc
http://tinyurl.com/23h4638
Feb 5, 2012. 1:25 PMstuffstuffa says:
could I remove the 470 ohm resistor and the 9v battery and attatch it to my computer's led power wires, cut right below the led and attach it there?
Jan 30, 2012. 4:14 PMShadowDragonz says:
For those still confused, you can find the original schematic for this at
http://www.555-timer-circuits.com/up-down-fading-led.html
Jan 30, 2012. 3:25 PMstuffstuffa says:
How could I do this with my computer? I want to make my case lights throb.
Jan 30, 2012. 3:32 PMstuffstuffa says:
I don't want to have to buy anything or solder, just something to control all of my case lights.
Nov 30, 2011. 4:43 PMrancid_84 says:
thank you!
Nov 17, 2011. 3:30 PMLazarus65 says:
For the life of me I can't seem to figure out how to connect the negative and the positive. I tried connecting it like I see in the picture: Positive to pin 8, and negative to pin 3, then I tried pin 1. Can anybody tell me if they got it right, and where they connected the power source?
Nov 20, 2011. 12:50 PMLazarus65 says:
I hope you do, because I end up coming back to this one by so many people who have successfully figured it out.
Dec 27, 2009. 8:59 PMbiteme556 says:
i have just made the fadeing light but i cant get it to fade when i put the battery wires in difrent places on the 555 timer and it will be bright in one spot and dimm in another but it doesent fade can you help me?
Nov 17, 2011. 10:50 AMnodoubtman says:
I only succeed fading once.. after nothing happens..what would be wrong??
thanks !:)
Feb 12, 2010. 4:06 AMbrit says:
Try it like this..
Dec 11, 2011. 7:00 AMmischka says:
Thanks for the schematic. It helped a lot building the circuit!
Oct 15, 2011. 5:11 AMUgifer says:
Thanks for the schematic - very clear and useful.
And MrBeta - good project. Thanks.
Nov 7, 2011. 8:26 PMnedfunnell says:
If I wanted to scale this up to about 80 LEDs, could I just change the transistor to one rated for the current and the resistor to match?
Oct 25, 2011. 4:55 PMtobster9103 says:
I cant seem to get my circuit to work. The led just stays on with no fading in and out. I have a 100uf 35v cap., a 2n2222a transistor, 555 timer, and the resistors in 1/8 watt. Would the resistors have to be 1/4 watt? What am I not getting here?
Aug 27, 2011. 1:29 AMsilentstone7 says:
I am trying to make something like this for a PC mod, using either 5V or 12V DC source voltage. I have no idea what to buy, with what specifications to make this work off that voltage. Can anyone help me out?
Oct 14, 2011. 9:27 AMUgifer says:
The 555 should be happy at 5V so the only things you might need to change are:
At 5V the current limiting resistor doesn't need to be so large - about 120 Ohm for blue/white or 150 Ohm for red I think.
The frequency might change as the voltage decreases (I'm not too sure on that one) so you might prefer to use the 100K pot in place of the 33K resistor so that you can tune it to your preferred rate.
Beyond that it should be fine.
Sep 28, 2011. 2:05 AMAnthony_Uk says:
Hi. The text description doesn't seem to match the schematic - For instance, Pin2 and 3 are not going to the NPN in the diagram, and your text only has one leg of the LED wired.
Feb 12, 2011. 4:26 PMzzzee says:
Hey i made the circuit but when i connect it to the power supply, the 555timer heats up and the LED stays on. Does anyone know what the problem might be?
Aug 3, 2011. 5:04 AMjmerisalu says:
I had exactly the same problem, I did the project 2 times had the exact pieces. Could someone help whats the problem?
Jul 28, 2011. 10:27 PMdoraemon3 says:
only 555 Timer works on the flashing effects, or is there other types of timer that works too?
Jul 15, 2011. 2:24 PMsume29 says:
hey.. do you know how i could increase the fade out time of the led?
Jul 4, 2011. 7:23 PMchipper35 says:
A top rate instructable!! ....I mean that!!
Jul 4, 2011. 6:48 PMbvan zijverden says:
Great job!
I have a question though :P , I will hook my circuit up to a 3.3v power supply. And I also use a 3.3v led, so what is my schematic for this?
Sorry I'm a bit of a noob when it comes to figuring out value's :(
But thanks for the instructions :)
May 27, 2011. 9:40 AMsprasad1 says:
I used the circuit as " Brit " says above. i replaced 33k R with 100k pot, 100uF with 1000, 220R with 470R, source 14.4V.    Flashing of 1 led did happen. But when i connected it to an array of 5(series) X 8 in total 40 led. Voltage dropped across output, only max of 10 led flashed and later on npn failed. now its not flashing, glows steady. Plz suggest me " Capacitor and NPN ". amp used by array is 250 mA and 3012 mW
Mar 19, 2011. 3:46 PMfourniersd says:
How can I get the LED to strobe from full brightness to completely off. When I build it with the specs you provide The Led goes from Full to about 30% brightness.
Jan 4, 2011. 9:32 AMcoleyy says:
i have transistors that are 2N3904, 2N3906, 2N5457, 2N2907A, 2N2222A, whish one(s) are NPN?
Mar 19, 2011. 3:10 AMrobot1398 says:
2n3904,2N2907A,2N2222A are npn
2N5457 is a n channel transistor
2N3906 is pnp
Mar 1, 2011. 4:41 PMjcaresheets says:
My first LED project I want to do is make a red LED heart for my fiance and I think I will add this into it and it will make a great gift. Thanks for the post.
Feb 1, 2011. 7:59 PMtinkerunique says:
Upon completion, the board can be coated with "rattle-can" urethane or varnish to stop oxidation. - Like many auto and boat controls.
Jan 2, 2011. 10:06 PMtexasdave says:
Mr Beta thanks for the video, it sealed the deal for my circuit, and also all your help on this. I modified it very slightly, I wanted a controllable slowwwww pulse, like, verrrrry slow. so I swapped the capacitor for a 220uf and a 50k trim pot. couldn't have gotten to this point without your help though!
Jan 23, 2011. 6:35 PMgmd393 says:
Dude, you confused me quite a bit. Your diagram doesn't have the 50k(var)/10k resistor connected right, it should go between terminals 2 and 3. You also should have the capacitor connected to terminal 2 and a jumper wire between terminal 2 and 6. Once I made these changes, mine started blinking.
Jan 29, 2011. 12:56 PMan4rchyy says:
I have gone by this schematic and no blinking occurred, and made the changes gmd393 said and still no blinking occurred. The transistor collector seems to be immediately applying power to the LED skipping the entire 555 circuit and staying on. I can disconnect all leads to the base and the LED remains on. I can't figure out why it won't work
1-40 of 123next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:MrBeta
