The end result is a constant fade up and fade down just like a Mac on standby.
Try it! See how small you can build it.
If you like it rate my Instructable. If you don't, rate my Instructable.
Remove these ads by
Signing UpStep 1Gather Tool and Components
Electrical Components
470 ohm resistor (or a resistor to drop the current for your desired led from around 8 volts.)
33k resistor ( or a 100k potentiometer for adjustable fade times)
LED ( I used Blue)
100uf Capacitor
555 Timer
Generic NPN Transistor
Copper clad board. breadboard, or project board.
Tools
Dremel or other rotary tool for drilling
1/32" drill bit for wires
Cutting wheel or tin snips if necessary to trim board down
Soldering iron
Scotchbrite pad or fine sandpaper. ( I used sandpaper because it happened to be there)
Muriatic Acid (concrete cleaner or pool chemical) Home Depot and other hardware stores have it.
Hydrogen Peroxide (standard wound cleaner) Found in drugstores, grocery stores, you probably have some at home.
Misc
Latex or Nitrile Gloves
Acetone to clean ink off of board after etch.
Outdoors area to etch in
Plastic or glass container to put etchants in.
Helping Hands clamp with magnifying glass (nice to have a third hand)
I've included the files for Express PCB software. Free download.
Fader.pcb2 KB| « Previous Step | Download PDFView All Steps | Next Step » |
The plus signs (+) are there to help with the polarity. They do not mean that you connect the positive voltage there.
The main problems I had when prototyping this project were the following.
Capacitor polarity
LED polarity
Proper/improper orientation of the NPN transistor.
Hopefully this clears things up a bit. Post a comment if you have any further questions or if you get it to work. And don't forget to rate my instructable.
The orientation of the resistors usually does not matter though the capacitor, the led, the transistor, and the timer MUST be positioned correctly.
http://tinyurl.com/23h4638
http://www.555-timer-circuits.com/up-down-fading-led.html
thanks !:)
Let me know how you get on.Good Luck :-)
And MrBeta - good project. Thanks.
If you get it working, please post a picture or a link so that I can show it here.
At 5V the current limiting resistor doesn't need to be so large - about 120 Ohm for blue/white or 150 Ohm for red I think.
The frequency might change as the voltage decreases (I'm not too sure on that one) so you might prefer to use the 100K pot in place of the 33K resistor so that you can tune it to your preferred rate.
Beyond that it should be fine.
I have a question though :P , I will hook my circuit up to a 3.3v power supply. And I also use a 3.3v led, so what is my schematic for this?
Sorry I'm a bit of a noob when it comes to figuring out value's :(
But thanks for the instructions :)
