3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Throbbing/Fading/Flashing LED with 555 Timer
Step 2Breadboard it
Breadboard it
Break out the breadboard and proto it up.
555 Timer
Pin 1- To Ground
Pin 2- Jumper to Pin 6, Jumper to Base of NPN
Pin 3- 33k resistor to base of NPN
Pin 4- Jumper to Pin 8
Pin 5- NC
Pin 6-Jumper to Pin 2
Pin 7-NC
Pin 8-Jumper to Pin 4, Connected to Positive voltage
Emitter of NPN to 470ohm resistor to LED
Base of NPN to + side of cap, then ground - side
Collector of NPN to + voltage
2 comments
Sep 28, 2011. 2:05 AMAnthony_Uk says:
Hi. The text description doesn't seem to match the schematic - For instance, Pin2 and 3 are not going to the NPN in the diagram, and your text only has one leg of the LED wired.
Jan 4, 2011. 12:07 PMcoleyy says:
is this the right way to hook up the 100k potentiometer?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:MrBeta
