Introduction: Thunderbolt Slide Arm
Hi guys this is my side arm of choice I designed after building several other slide action pistols that all had there disadvantages e.g broken pieces bad range flimsy design. So after 4 hours of work I present to you one of the best slide action pistols. Pros: Fast reload (because of the slide 2RPS), Mag in Handel, Good range (25-30ft), Can hold a lot of rubber, No broken pieces, Sturdy design, Looks good (in my opinion). Cons: Trigger is a bid naff (if someone designs a better one ill add it to the instructions).
Step 1: Barrel and Trigger
This is all simple just follow
Step 2: Handel/Mag
Pretty much you bog standard Grey piece mag
Step 3: Barrel Continued
Just follow to finish the barrel
Step 4: Slide and Ram
Make what you see
Step 5: Bands
Here are all the band placements the ones for the slide must go on this way. Don't forget to comment and follow for more awesome guns. Happy shooting!! P.S don't overload the ram with bands or you won't be able to pull it back and always pull it right to the back of the ram guide.
