Tic Tac Tunes - Now with Tic Tac Beat Box
Step 1Parts and Tools Required
As well as standard workbench tools and soldering equipment, you will need :-
1 x PicAxe 08M or 08M2 microcontroller chip - see below
2 x 10K resistors - all are 1/4 or 1/8 W
1 x 330R resistor
1 x 22K resistor
1 x 560K resistor
1 x red LED
1 x 10K linear dual gang slide potentiometer (60mm).
2 x 1N4148 or similar diodes. Just about any small diode will do
1 x 0.1 uF capacitor (10V or more)
1 x 28mm x 4mm piezo sounder. This MUST be a low profile type or it won't fit
1 x PX28A 6V keyfob battery (4LR44 PX28A A544 L1325 equivalents)
1 x stereo 3.5mm jack socket
1 x jack plug for probe. This can be 2.5 or 3.5mm, mono or stereo
1 x stripboard 22 x 12 holes
1 x spring from a retractable pen
1 packet of TicTacs. Your choice of flavour
You'll also need a few bits of link wire and something to decorate it. I used the old Blue Peter favourite - sticky back plastic.
If you need to brush up on your soldering technique, there's an excellent guide HERE.
Most of my parts came from Maplin (UK), but Mouser or your friendly local on-line electronics store will have these in other parts of the globe. All the parts (including Tic Tacs and battery) shouldn't come to more that 10 pounds (16 dollars), but that may vary depending on where you are, and doesn't include p+p, or the programming lead (see below).
I've used a PicAxe 08M microcontroller which comes as a blank chip and needs to be programmed. To do this, you will need a programming lead and the free programming editor software. Both the PicAxe chip and the lead are available from Tech Supplies in the UK or see HERE for other countries.  The 08m has been superseded by the 08m2 - Either will work.
Once you have the lead, you only need a PicAxe, two resistors and whatever sensors and output devices you choose to have a full PicAxe development kit which can program any of the PicAxe range, so you can design your own projects. I have an Instructable planned which will get you well on the way.
7 comments
Oct 13, 2011. 2:24 AMgada888 says:
I found the picaxi 08M and pic12f683 out in market.are they the same thing?
Oct 25, 2011. 10:51 PMjwoo2023 says:
no, PICAXE is pre programmed so that you can 'program' in BASIC unlike PIC which is different
Sep 12, 2009. 9:20 PMamanihoot says:
where did you get the supplies?
Sep 14, 2009. 12:49 PMshawntherobot says:
would radio shack have the supplys and how much did it cost all together to make it
Aug 9, 2009. 11:15 AMjeff-o says:
What is the center frequency of the piezo element?
Aug 2, 2009. 8:50 AMikestarm17 says:
what is a 330R resistor? I don't get the R
Aug 3, 2009. 1:56 AMunigamer says:
330 ohm resistor. Nothing fancy and very easy to find as they are commonly used as current limiting resistors just as it's being used here.
Aug 3, 2009. 12:27 PMikestarm17 says:
k,thnx
Jul 13, 2009. 8:07 AMgrundisimo says:
how much you get computer for?
and where?
Jul 15, 2009. 4:34 AMKiteman says:
(I think he was asking about the picAXE chip)
Jul 15, 2009. 6:02 AMKiteman says:
I suspect Grundisimo's first language is not English - translation software or a poor dictionary could be to blame.
Jul 15, 2009. 10:10 AMgrundisimo says:
Jeg er virkelig kede lige nu.
Jul 15, 2009. 5:17 PMgrundisimo says:
yes that is danish. (want me to start speaking in swedish)
Jul 15, 2009. 10:11 AMgrundisimo says:
oh sorry stupid translater stopped working for a minute. that says i am bored right now.
Jul 15, 2009. 10:21 AMKiteman says:
Does that mean I'm right?
Jul 15, 2009. 5:16 PMgrundisimo says:
depends....... i wasn't really paying attention to the comment above.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
121
Author:AndyGadget
