3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Tic Tac Tunes - Now with Tic Tac Beat Box
Step 5Circuit Diagram
Circuit Diagram
As space is at a premium here, I'm using a small 6V battery and dropping the voltage down by 1.2V to 4.8V with the diodes D1 and D2. The PicAxe chip is happy up to 5V so this is fine.
R1 and R2 are required to allow this to be programmed in-circuit and to re-program I plug in the USB / serial programming lead to the 3.5mm socket under the box lid.
The 0.1uF decoupling capacitor is good practice with any circuit. It absorbs the voltage transients when transistors within the ICs switch. Without these, digital circuits can behave very strangely.
R3 is to pull the input to ground when the probe is not touching the track, otherwise it floats and generates all sorts of spurious noises. The solder blob on the track is to the positive rail to give a definite level for the control.
I've used a wide angle red LED but any LED will do. Drop R5 to 150R or so if using blue or white. There's not a lot of LED activity so as to keep the current consumption down.
Current consumption is around 1mA when active and drops to 200uA when in sleep mode, so the battery should last a fair while.
I used ExpressSCH to draw the schematics, and PDF Redirect to save to a PDF file. Both free.
TicTac.pdf(595x842) 9 KB
3 comments
Jun 22, 2011. 9:05 AMfutureventions says:
With the peizo sounder, what colour wire attaches to the Picaxe?
Aug 9, 2009. 10:50 AMjeff-o says:
Would the circuit run on just 3 volts?
Aug 10, 2009. 6:54 PMjeff-o says:
Ah, I see. So, I could temporarily hook up 5V during programming, and the rest of the time run it from a 3V lithium cell?
Aug 11, 2009. 10:04 AMjeff-o says:
Naturally. ;) I suppose I'd also have to change the resistor for the LED, but that's a trivial change. Oh, and I'll have to make sure the piezo is happy running on 3V as well.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
122
Author:AndyGadget
