Tie-down Clamps
11,894
58
13
Posted in WorkshopLighting
Introduction: Tie-down Clamps
About: Eric J. Wilhelm is the founder of Instructables. He has a Ph.D. from MIT in Mechanical Engineering. Eric believes in making technology accessible through understanding, and strives to inspire others to lear...
Often, I can't find a clamp big enough to hold a project together while glue is drying or while I drive in some screws. Tie-downs are a good alternative, but can damage the edges of wood projects.
Additionally, there's often a great deal of friction when the webbing goes around a corner leading to uneven tension.
To fix this I made myself some tie-down clamps.
They are blocks of wood with rollers on the end. If you use cheap pine, they won't dent nicer hardwood when you clamp down on it.
Step 1: Cut Out Pieces
I made these 15 inches long with 1.25 inch spacers from a 2x4 using a miter saw.
Step 2: Connect Pieces
The hand drill was in use at another project, so I made the connections with biscuits and glue.
Step 3: Square Edges
Square the edges with a miter saw, and sand smooth the surface you will place against your work.
Step 4: Make/find Rollers
I've used skateboard wheels, plain bearings, and hardwood dowels. They all work about the same. A hardwood dowel piece is probably the easiest, especially if you have lathe (link to ifabricate description of a lathe).
Step 5: Drill and Install Rods
Drill holes for the rods such that the rollers will not touch the ground. In my first set, the skateboard wheels extend beyond the 2x4. This is problematic because the clamps roll when you put a work piece on top of them.
I tried nails and bolts for the rods. Bolts are a bit easier.
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    13 Comments
    I clicked on third picture down from the start and now I understand..... thanks guys
    yea an instruction video would be great. I like the idea of tie down clamps. some times I don't have long enough clamps but I do have very long tie downs in my truck. what are the rollers for?
    Clever idea. Maybe an explanatory video could improve this good instructable.
    Could you explain their usage, or show a picture.
    They look like blocks of wood with wheels on (good for skating), and I don't see how you would tighten two of these to something. Any chance of a picture and an explanation?
    Thank you in advance
    its a great idea, i'd be extremely careful to make sure everything is true and square otherwise your work will end up out of square.
    Man, that is a great idea. I've been using tie-downs (aka band clamps) and found them darned awkward at best. You sure came up with a very cool method.
    my only question..is what do you use to hold these together while you're gluing/screwing them up? heheh very good solution to the marred wood you usually get with just a strap clamp type deal
    Gatonegro, you can see a picture of these in action. Look at the Intro, and go to the third picture (below the large picture).
    i don't get it. can you post a photo of these being used? or the finished ones so I understand how they work. I need to make a huge table and these seem to be what I need. thanks.
    These are some awesome clamps I could have used these earlier this month...and I am definitely going to make a set.
